how do I replace the black plastic engine oil filler neck in '01 E320? - Mercedes-Benz Forum
post #1 of 5 (permalink) Old 06-04-2009, 04:05 AM Thread Starter
Date registered: Oct 2004
Vehicle: '99 E320, '01 E320 wagon, '01 E320
I had a slight oil leak around the engine oil filler. At first, I thought it was the
oil cap. Installed a new one and cleaned up the entire area. A few days
later, the oil returned. I have now discovered that the oil is leaking from
between the oil filler neck and valve cover.... Not a major leak... maybe
a small teaspoonful every couple of weeks... but enough to dirty up my
engine....
how do I replace the black plastic engine oil filler neck in '01 E320? I can't
tell how the neck is supposed to be removed. I do not want to accidentally
break off a piece of it and have it end up inside the engine....
THANKS IN ADVANCE!
kathy_moore is offline
post #2 of 5 (permalink) Old 06-04-2009, 05:18 AM
Date registered: Feb 2007
Vehicle: 03 E320 4M Wagon & 97 E320
Quoted: 12 Post(s)
Looks like there is an O ring under there. Item 41 and the part number is 1110180080.
If you go to a dealer to buy the O ring, the parts guy may put it on for you.
loubapache is offline
post #3 of 5 (permalink) Old 06-04-2009, 07:26 AM
Date registered: Jun 2009
You have to replace the entire left valve cover. Just replaced mine last night. If you plan on doing the job yourself, purchase the oil filler neck along with the valve cover, valve cover gasket. I had to actually take the cover that the oil filler is attached off the valve cover. Then I used a philips screw driver to unscrew the oil filler neck. I found out that the oil filler neck turns to the left to remove. There is a tab keeping it from turning. You have to remove the filler neck before you remove the valve cover. Standing on the drivers side of the car, pull the oill filler neck towards you and then turn the neck to your left. I took the valve cover apart, it was easier for me.
Hope this help.
liljay is offline
post #4 of 5 (permalink) Old 06-04-2009, 08:10 AM
Quoted: 12 Post(s)
I think the OP said the leak is from between the oil filler neck and the valve cover, not from the valve cover gasket.
You described the removal of the oil filler neck so the OP just needs to replace the O ring on the bottom of the neck.
The neck is removed like the filler cap (turning counter-clockwise), once the lock tab on the driver's side is released, no?
post #5 of 5 (permalink) Old 05-17-2015, 05:46 PM
Date registered: Jul 2010
Believe it or not the oil filler neck attaches to the valve cover the same way that the oil filler cap attaches to the neck. Use a strap wrench (or channel locks) to rotate the oil filler neck CCW about 90 degrees and it will come right off. I love German Engineering.
Cedarite is offline
    Leak from oil filler neck - how to remove? cheyne R170 SLK-Class 3 03-06-2013 01:19 PM
    do most people pour new engine oil down oil filler hole or the oil filter housing? kathy_moore W210 E-Class 6 02-23-2009 12:40 PM
    Fuel filler neck Ohgeun General Mercedes-Benz 0 01-23-2009 03:42 PM
    oil filler cap neck leak funnyguy1 R230 SL-Class 0 06-18-2007 08:58 AM
    WTB 95 C280 engine plastic cover? Toward frnt of engine Black Plastic with Bnz logo. Bryan858 For Sale/Wanted/Trade/Giveaway 0 01-08-2007 10:33 PM
