1999 C280 Radiator & Fan Assemblies - Mercedes-Benz Forum
post #1 of 1 (permalink) Old 06-02-2009, 10:46 PM Thread Starter
Date registered: Jun 2009
I recently bought my first mercedes; a 99 C280. I has front end damage, and all cooling radiators & fans have been removed. It would be sooo helpful if someone with a 97 -2000 C280 could post some snapshots of the radiator area
with shots from both the front as well as behind. I would normally consult a manual, though I have so far only come across a $100+ repair manual published by Bentley. I am mainly trying to make certain that I purchase all the parts needed. If someone could even also list wether the transmission cooler is built into the Radiator, as well as if there is a separate engine oil cooler, etc.
Please post photos of a 99-2000 so I can see the correct V-6 parts, thanks.
mcolinp@gmail.com is offline
    3x30 amp fuses under plastic lid - blower fan, aux radiator fans, window defogger wildeyeguy R129 SL-Class 33 02-18-2014 06:01 PM
    Head gasket leveled, New Radiator, new Thermostat, New fan clutch, both Auxiliary fan Workersvillage W124 E,CE,D,TD Class 11 08-10-2008 10:32 PM
    1995 C280, eng codes & eng fan problems megsscrilla W202 C-Class 3 07-28-2008 09:20 PM
    Replace Aux Radiator Fan Motor 1995 C280 BadBoy W202 C-Class 1 05-24-2008 08:35 AM
    engine fan or radiator fan fuse and relays ?? DnBtekhnic W203 C-Class 0 04-21-2008 08:40 AM
