Software glitches in Comand system - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 05-31-2009, 08:56 PM Thread Starter
Iridium's Avatar
Date registered: May 2009
Vehicle: 1984 300D Turbo, 2009 GL320
Quoted: 4 Post(s)
Hi all
New member here, so I hope this hasn't been covered already. The 2009 GL320 Bluetec is my first MB and I'm still getting used to the "Mercedes way" of doing things. (Battery under the front seat, etc.)
So far everything is good except for some odd glitches in the COMAND system. Frequently the digital clock freezes, while the analog continues keeping perfect time. Pressing any button on the COMAND unit gets the clock going again, but I'm wondering if there's a software update or other fix to resolve this.
On the dash, the temperature gauge sometimes locks up too, at unrealistic temperatures. Today it was working fine until I had the car washed, then it stuck at 69 degrees for the rest of the day. Actual temperature was over 95 degrees. Even after two starts and several hours in the sun, the temp gauge stayed at 69. This happened on delivery day too, stuck at 70 degrees on a 100-degree day, but resolved itself after a few hours.
Yesterday, I started the car and the COMAND unit automatically linked to my Bluetooth phone as it is supposed to do. But then it started ringing with the message, "INCOMING CALL FROM UNKNOWN". But there was no call -- my phone was not ringing. The car wouldn't stop ringing even if I tried to answer the "call". If I pressed disconnect, I'd get another "call" a few seconds later. I finally resolved this one by shutting off my phone, so it may have been a phone-related glitch instead.
I love driving the car and expect to have it for many years, but I have to say I'm unimpressed with the complexity of the COMAND user interface, and software glitches are just inexcusable. Any suggestions for resolving these, or should I just go to the dealer and hope they have a software update?
Thanks
Iridium is offline
post #2 of 2 (permalink) Old 05-31-2009, 10:19 PM
Diesel Benz's Avatar
Quoted: 39 Post(s)
Considering your phone problem, I would check if there was a SW update for it and if possible, I would try another phone. It really looks like a phone issue. But isn't BT HF integrated to Comand in your car, if the Comand unit is misbehaving, never know if this phone issue is another symptom.
The digital clock freezing (on the Comand?) sounds like a SW issue with the unit. But I tried to find out some previous knowledge about a similar issue and found nothing. Sounds like it was no known fault. You might get better replies from owners at the GL forum, hopefully here too. A SW update, if available, would be a good thing to start from.
A bit similar with the temperature gauge, I would try to take a photo of it malfunctioning and show it at the dealer. After all, everything in your car should work and should be fixed under warranty. Intermittent issues are just a bit difficult sometimes.
Diesel Benz is offline
    Shall I replace my COMAND? or just the Software? giorgoc Audio & Telematics Forum 32 11-09-2012 01:06 AM
    COMAND Software DansSlk Audio & Telematics Forum 10 07-09-2006 07:31 PM
    Comand software update firemist350 R171 SLK-Class 12 03-22-2005 06:23 AM
    Software crash on COMAND system kmm&m W211 E-Class 5 06-30-2004 10:28 AM
    ML Software glitches. tcp_ML500 W163 M-Class 15 05-13-2003 09:15 AM
