Transmission problem - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 05-31-2009, 03:56 PM Thread Starter
Date registered: May 2009
My 1989 300SEL just stopped shifting into high gear. It was running at 3200 RPM at 65MPH. Any suggestions as to what the problem and cost to repair could be and what kind of damage could be done if I continue to drive it.
Tosser123 is offline
post #2 of 3 (permalink) Old 05-31-2009, 05:35 PM
Date registered: Feb 2008
Vehicle: 1987 420SEL
Rebuilding one of these can run up to $2500, which tends to be the solution as with a replacement, you really never know the exactly condition of the internals.
Try searching around the W126 forum on this site. There are some very helpful threads in there, just search '300SEL transmission issues' or something along those lines.
Before you get too serious about a replacement, do the normal service to the trans (ATF change, filter, pan gasket) and see what happens.
(On Edit)
They're finnicky to fill with fluid though; if you drain the torque converter, use the amount listed in the owner's manual. There should be values including the TC, and w/o. Fill the transmission about 3/4 full, keep track of the quantity that's in there, and drive the car. Check, add as necessary, repeat. This will continue for a couple days until the reading is consistant. Shift through all the gears before checking.
Benz Prodigy is offline
post #3 of 3 (permalink) Old 05-31-2009, 07:56 PM Thread Starter
Trans Problem
Thanks for the input.
    Help with transmission problem CLK forever C208/A208 CLK-Class 14 08-25-2007 12:44 AM
    Transmission Problem J-Ro R129 SL-Class 0 06-12-2006 07:05 PM
    Transmission problem? Avezbakiyev W210 E-Class 22 09-14-2005 01:17 PM
    Transmission Problem shark22 R171 SLK-Class 25 08-11-2005 02:22 PM
    Brake padal vibration problem + transmission problem Majid Mansoori W210 E-Class 11 09-22-2003 07:33 PM
