300sd blow by - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 05-31-2009, 07:14 AM Thread Starter
Date registered: May 2009
300sd blow by
I've got serious blow by on '84 300sd. (I can only partially remove oil cap because so much oil is coming out. I don't want to create a huge mess.)
My question: Can I continue to drive, or will the car worsen and leave me stranded?
rickhattersley is offline
post #2 of 4 (permalink) Old 06-02-2009, 01:16 AM
mbkomfort's Avatar
Date registered: Jan 2008
Vehicle: -88 250D, -93 280TE-24 Sportline and -00 E270T CDI
Hi! Some blow-by is normal on an old diesel, and most of the oil is thrown out by the timing chain when you lift the lid. there is less blow-by under load (driving) and more at idle (when you check)
Does it blow oil into your air cleaner?
How is your oil consumption and cold starting?
And what is it's mileage and how has it been serviced? (oil changes, valve lash adjustments?)
VERY high oil consumption and difficult cold starting are signs of engine wear..
Good luck
mbkomfort is offline
post #3 of 4 (permalink) Old 06-02-2009, 01:20 AM
GogglesPisano764's Avatar
Date registered: Feb 2008
Vehicle: 1983 300D Turbo Diesel
Send a message via Yahoo to GogglesPisano764
Welcome to Benzworld!
Yes Honey! Thats how they sound! Its a diesel!
MBCA Member
1983 300D "Schultz" (Relocated to Canada)
1983 300D "Klaudia" (My new love)
1985 300D (Whipped then Stripped)
1985 300SD (In way over my head and let go)
2002 Suburban Z71 (Eats gas stations during trips)
2004 Aveo (Only because I enjoy stuffing my fat ass in a tiny car. Oh and it gets good gas mileage)
GogglesPisano764 is offline
post #4 of 4 (permalink) Old 06-04-2009, 10:34 AM Thread Starter
Good luck
I just bought the car and the guy was Korean and spoke little English. I could get only limited information from him. I asked about history but he gave no discernible answer.
The air filter is clean, though it appears new. There is definitely oil inside the oil filter compartment, however. Not sure how old and how long it's been there.
As for cold starting, it has not had a chance to be started in the winter. (I bought it two weeks ago.) The mileage appears to be 1.1 million (odometer: 136,000). And the oil consumption is hard to tell because it leaks.
Here is what I do know and what I can tell you to help me:
The engine does not smoke badly at all -- no white smoke and no black smoke almost at all.
The car's biggest problem (to me, at least) is that it struggles uphill, moving only 35 mph or so and hesitating very badly. On flat surfaces it drives almost perfectly. It's the hills (and grade, even the slightest) that slow it down. I can't even get on the freeway, given how dangerous it is to drive slowly there.
However, when I fill the tank up, it does drive better, tackling hills much better but still not at full power.
    Heat blow on Passenger side, but blow cold on drivers side? LesG W140 S-Class 3 03-18-2009 01:28 AM
    Hamas tried to blow Abbas..I mean blow him up. maine_coon Off-Topic 0 05-17-2007 05:50 PM
    Question RE Interchangeable parts 1979 300SD - 1983 300SD Reedfarm W126 S,SE,SEC,SEL,SD,SDL Class 2 10-03-2004 08:03 PM
    Blow-by on a 300SD?? w108 W126 S,SE,SEC,SEL,SD,SDL Class 4 06-22-2004 10:08 PM
    Blow-Off-Valve on a 300SD Twizted W126 S,SE,SEC,SEL,SD,SDL Class 12 08-07-2003 11:34 AM
