Moisture trap on diesel engines - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 05-28-2009, 04:00 PM Thread Starter
Date registered: Apr 2009
On a previous post there was a question about having a moisture trap on turbocharged diesel engines.
Some diesel engines that are turbocharged have a small drain valve usually located near the after-cooler. In theory there is condensation from the air that is compressed by the turbo. The thought is that humidity in the air will condense when compressed.
This is typical in high HP marine diesel engines. These are engines that will burn more that one gallon of diesel per minute.
Normally when the engine is turned off and the air pressure in the turbo is equalized with the outside air the water will automatically drain off from this valve.
Not sure if any of the MB diesels have this feature.
My opinion is that this valve system is not required or is anything to worry about.
bvalters is offline
post #2 of 4 (permalink) Old 05-28-2009, 05:22 PM
Kajtek1's Avatar
Quoted: 1223 Post(s)
Never have seen it.
How often you take your Mercedes on the water?
This guy might need it.
Kajtek1 is offline
post #3 of 4 (permalink) Old 05-29-2009, 09:57 AM
Date registered: May 2005
Vehicle: '07 GL320CDI
Quoted: 2 Post(s)
Yes, plenty of heat left over to dissipate the moisture.
Extrapolating marine experience to auto experience seems of little value.
Kent Christensen
Albuquerque
'07 GL320CDI
lkchris is offline
post #4 of 4 (permalink) Old 05-29-2009, 11:19 AM
Musikmann's Avatar
Quoted: 6 Post(s)
Thanks for the further info guys.
Musikmann is offline
    tuneing ! diesel engines nail it V-Class 0 04-11-2008 11:35 AM
    Maybachs with diesel engines H-TownBenzoboy Maybach 26 09-16-2005 12:12 AM
    Comparing Engines Gas vs Diesel Braingears G-Class 12 08-17-2003 08:41 PM
    OT Q: Are diesel engines more reliable than gasoline engines, and if so why? Thnx. Cap R170 SLK-Class 2 11-13-2002 05:44 AM
    used diesel engines Guest (MBNZ) Unimog 2 10-12-2001 12:57 AM
