What is Redline Additive? - Mercedes-Benz Forum
post #1 of 11 (permalink) Old 05-27-2009, 02:37 PM Thread Starter
Date registered: Apr 2009
I have a 2008 ML320 Diesel.
I just had an oil change at my local MB dealer. Besides the synthetic oil there was also a charge for Redline Additive (costs of $16.98). I asked the service manager what exactly this was and he said that they add this to all MB diesels.
Any thoughts?
bvalters is offline
post #2 of 11 (permalink) Old 05-27-2009, 02:45 PM
Musikmann's Avatar
Quoted: 6 Post(s)
Red Line Oil
Musikmann is offline
post #3 of 11 (permalink) Old 05-27-2009, 03:43 PM
Kajtek1's Avatar
Quoted: 1226 Post(s)
Red Line is having good recommendations for their products, but on the other hand MB very seldom approves any additives to their cars.
I would ask again what exactly was added to your car.
Assuming that you are in US, the only oil approved for cdi engines is Mobil 1 ESP Fomula M
Make sure this is what they gave you .
Welcome to the forum
Kajtek1 is offline
post #4 of 11 (permalink) Old 05-27-2009, 04:25 PM
Musikmann's Avatar
Quoted: 6 Post(s)
Ditto to Kajtek1. I seriously doubt that the stuff is an MB-approved product. I'm not saying it will hurt anything and if the dealer added it you should be covered if any warranty issues arise.
As an aside, even though MB offers their own fuel system additive, my dealer had never heard of it and instead uses some of the BG products. But again, probably harmless and not MB-approved either.
post #5 of 11 (permalink) Old 05-27-2009, 04:36 PM Thread Starter
Thank you for the reply.
I agree that MB probably does not approve the use of Red Line products. I am going to ask my dealer not to include this product in the next oil change. Attached is the Red Line site.
BTW... this was a $225.00 oil change with tire rotation. Talk about ringing the bell.
Red Line Oil
bvalters is offline
post #6 of 11 (permalink) Old 05-27-2009, 04:42 PM
Musikmann's Avatar
Quoted: 6 Post(s)
From what I've heard, diesel oil changes are more involved and time consuming than those for gas cars. I would pay about $125 for what you had done.
post #7 of 11 (permalink) Old 05-27-2009, 06:28 PM
Kajtek1's Avatar
320cdi has lower oil capacity than 320 gasser. The only difference is that to get to the suction tube on newer engines you have to unscrew the cover.
Still 5-10 minutes job, assuming that mechanics, as usually cheat on oring replacement.
About $50 for oil, $12 for the filter, so aether price makes hefty hourly wages.
Kajtek1 is offline
post #8 of 11 (permalink) Old 05-27-2009, 07:21 PM
Musikmann's Avatar
Quoted: 6 Post(s)
Kajtek1, I thought there was some sort of moisture trap that needs to be cleaned or drained? What is that about the o-ring? But of course you are correct, the dealer labor charges are too high for most of what they do.
post #9 of 11 (permalink) Old 05-27-2009, 08:54 PM
Kajtek1's Avatar
Moisture trap? Never heard about.
MB filter shaft has several orings on it and this is the only item that can stain white gloves on oil change using suction. Replacing those orings takes usually longer than actual oil change and is not critical unless orings got cut.
How do you know for sure your orings were changed in the life of your car if you do oil changes at the dealer?
How do you know the filter was changed as a fact?
When I did my first oil change on the "dealer serviced" Mercedes, the filter was "extra crispy"
Don't think it become so brittle in last 13,000 miles if you follow what I mean?
Kajtek1 is offline
post #10 of 11 (permalink) Old 05-28-2009, 01:41 PM
Musikmann's Avatar
Quoted: 6 Post(s)
Thanks for additional info Kajtek1 and yes, I know exactly what you meant.
    Redline flighht2k5 Unimog 5 09-12-2007 06:02 PM
    B20 and Redline BH126 W126 S,SE,SEC,SEL,SD,SDL Class 2 12-02-2006 11:05 PM
    Redline Diesel Fuel Catalyst & Redline 85??? regsatx W126 S,SE,SEC,SEL,SD,SDL Class 2 10-06-2004 09:22 PM
    NO REDLINE ON TACH ESTE W163 M-Class 3 09-04-2004 08:10 PM
    Nate, the fuel additive is Red Line Diesel additive- imrov. 30 to 33 mpg Guest (MBNZ) W201 190-Class 2 02-16-2002 10:19 AM
