C220 Automatic CDI Not starting - Mercedes-Benz Forum
post #1 of 7 (permalink) Old 05-27-2009, 09:14 AM Thread Starter
Date registered: Nov 2008
Red face C220 Automatic CDI Not starting
It takes several attempts to start my 2000 C220 CDI. When I turn the key the starting 'process' just does not begin at all. I turn the key off, wait for the immobaliser to engage, and try again. It can take up to 10 attempts before the car starts. It almost appears as if the gear leaver is not in the 'P' position. ANy ideas ??
Thanks & Cheers
simonbe is offline
post #2 of 7 (permalink) Old 05-27-2009, 10:34 AM
Diesel Benz's Avatar
Quoted: 39 Post(s)
Thanks & Cheers
If the key turns in the ignition slot, then it is not the gear position switch.
How does it work with your second key?
Diesel Benz is offline
post #3 of 7 (permalink) Old 05-27-2009, 10:43 AM Thread Starter
I dont have a second key, unfortunatly
simonbe is offline
post #4 of 7 (permalink) Old 05-27-2009, 11:31 AM
Quoted: 39 Post(s)
I should not ask people to try their second key, for some odd reason that always makes their second key disappear. Now you cannot be sure if it is the power coil in the key loosing contact from its soldering. Unless you open the key. But it could well be the EIS too, not extremely rare.
post #5 of 7 (permalink) Old 08-31-2009, 01:43 PM Thread Starter
Still No Joy
OK I bougt a new key but it still does not work, in fact it now will not start at all (with old or new key). When I turn the key there is just a 'clunk' sound at the top left side of the engine, almost as if something is 'stuck'.
Any Help........please
simonbe is offline
post #6 of 7 (permalink) Old 08-31-2009, 02:32 PM
Quoted: 39 Post(s)
Sounds like a very traditional starter motor/solenoid issue, nothing about the complex electronics of modern MBs. You can diagnose it by measuring the voltage from the solenoid input. If you can measure a proper drive signal, the starter motor or solenoid have issues.
post #7 of 7 (permalink) Old 08-31-2009, 02:47 PM Thread Starter
Sounds like the First bit of real progress
Hey, thanks for that. As a mater of fact I had to 'override' the solenoid about 6 months ago as the gear stick was stuck in 'P'. Now I need to get someone to measure the voltage.
simonbe is offline
    C200 cdi v c220 cdi are they same engine? h9llw W203 C-Class 2 01-03-2011 01:35 PM
    C220 CDI kevin b Benzworld Site issues forum 0 01-23-2009 04:29 AM
    C220 CDI Coupé Automatic gearbox problems! - PLEASE HELP! warrenrs W203 C-Class 0 04-14-2008 12:49 AM
    C220 CDI Manual vs automatic Bhans W203 C-Class 6 11-09-2002 07:22 PM
    Driving a C220 CDI Automatic this week on the Autobahn... Chuck V W203 C-Class 0 08-23-2002 02:38 PM
