Fuel Tank or Gauge? On aVito 108CDI - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 05-26-2009, 09:40 AM Thread Starter
Date registered: May 2009
Vehicle: 02 plate Vito 108CDI
Question Fuel Tank or Gauge? On aVito 108CDI
Hi, I just bought an 02 plate Vito 108CDI. I think I got a pretty good deal. The guy I bought it from said don't let it go below 1/4 tank or it'll cut out.
My friend seems to think there may be water in the tank and I will have to drain the tank and see if there is. Or the Gauge just could be faulty meaning 1/4 means empty. Any ideas?
jakeyboy76 is offline
post #2 of 3 (permalink) Old 05-26-2009, 11:20 AM
Kajtek1's Avatar
Quoted: 1070 Post(s)
The fuel pick up is at the bottom of the tank, so if there is water in it -it would be the first one to be sucked.
Welcome to the forum. I see you already filled up the user info what makes you good starter.
Generally diesels loosing fuel prime are pretty hard to restart, so it is not advisable to run them dry. I like to make full use of my tanks (while I estimate most of the owners fill up still having 30-40% tank full) and on newly purchased vehicles carry spare can of fuel and try to run on the reserve. With diesel I am trying to avoid running dry, so usually after experiencing that I can drive 70-80 miles with the reserve on, I am satisfy and add some fuel. Fill up at this point is giving me realistic tank capacity, what quite often is 10% higher than the official data. That is also giving me an idea what is my real life range on the tank, what is very helpful while driving in Nevada and California where gas station can be 40 miles apart, not to mention that desert stations are price gouging, while cites with good prices on fuel can be 150 miles apart, so planning fueling there can save quite few bucks.
Kajtek1 is online now
post #3 of 3 (permalink) Old 05-26-2009, 11:42 AM
Diesel Benz's Avatar
Quoted: 32 Post(s)
As above, if there was water, it would be sucked first irrespectively if the tank was full or almost empty. It could be a small leak at the fuel feed line (between the fuel pump and the tank).
Diesel Benz is offline
    Fuel Gauge / tank issue CQRT R129 SL-Class 26 07-15-2010 02:02 PM
    Fuel tank takes quarter tank full of gas less than what it used to take! Labik34 W140 S-Class 13 07-19-2008 04:15 PM
    Fuel gauge "not full" when tank is filled tempoct R170 SLK-Class 6 02-06-2006 10:43 AM
    Was something loose? I filled my gas tank, and my fuel meter never reset to the full tank reading.. AC_ML W163 M-Class 5 08-20-2004 07:12 AM
    Fuel Gauge is NOT Working? After fill up the tank, the needle tjhsiao W163 M-Class 13 10-18-2002 09:25 AM
