Door lock bounce w203 - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 05-25-2009, 02:59 AM Thread Starter
Date registered: May 2009
Hi Guys
Further to all discussions posted on the above topic, I think there might be a cheaper alternative to replacing your door locks/actuators.
I have recently replaced two (driver's door lock and rear left door lock) of mine. I am no technician or fundi but I stripped my faulty locks and found that a little spring could be the resultant cause of the door lock bounce. I have attached a picture of the spring and relative size to a common paper clip. The problem is the spring was lying loose inside each of the locks that I stripped. It is really difficult to ascertain where the springs fit and I cannot tell whether the spring has been broken or not...I cannot see any other pieces of it anywhere. If anybody has knowledge of this please advise as it could save lots of people a considerable amount of money. Also, it would make it relatively simple to repair if somebody has an exploded diagram of the lock.
Kind regards
Sanjiv is offline
post #2 of 2 (permalink) Old 05-25-2009, 01:59 PM
gerkebi's Avatar
Date registered: Oct 2005
Vehicle: 107, 115, 116, 123, 124, 126
Welcome aboard! Please join us in the W203 forum and share your great tip...
gerkebi is offline
    door lock: how to disconnect from pneumatic hose and door handle? good1 W210 E-Class 5 08-20-2016 06:17 PM
    Door Lock Solenoid "Bounce" problem boiler81 W203 C-Class 12 05-04-2012 01:05 PM
    Merc W203 C Class Passenger Side Door Lock Help Please! poolie W203 C-Class 2 05-26-2007 02:11 AM
    300SD door lock issue (can't lock with key, but can unlock) Mugsy90/10 W126 S,SE,SEC,SEL,SD,SDL Class 5 11-12-2006 06:12 PM
    WARNING:Make sure your hatch door manual lock is set or the hatch door will not lock with the remote AC_ML W163 M-Class 10 12-17-2003 10:16 PM
