W123 did any have 3 speed auto gearbox? - Mercedes-Benz Forum
post #1 of 6 (permalink) Old 05-25-2009, 02:40 AM Thread Starter
Date registered: May 2009
Post W123 did any have 3 speed auto gearbox?
I have just inherited my late grandfathers mercedes w123 230e in ivory paintwork. He was a private chauffer so every time the car was used it was washed and covered in a garage for the last 24 years.
The car has covered 93000 miles and is in immaculate condition.
I have been using it regularly on motorways. Should the car have a 3 speed auto gearbox?
when at 80mph the engine is running at 4000 rpm, is this correct or should it change up into another gear which it is not doing?
everything else on the car is faultless, im just wondering if the gearbox has developed a problem where it did not move for nearly 2 years.
simonleach is offline
post #2 of 6 (permalink) Old 05-25-2009, 05:28 AM
Date registered: Jan 2009
Vehicle: 1977 230, 1990 300E 2.6
I have an early U.S. spec W123 230, carburetor version - production date 10/76. AFAIK, all were 4 speed automatics. If you are not familiar with these transmissions, they start out in 2nd gear so you will only feel 2 shifts. It is possible to get the car to start in 1st by (while at a stop) moving the selector lever all the way down into low then back to drive. Unless you really put your foot into it, the trans won't stay in 1st very long.
As far as the RPMs, the gearing on these cars with just the 4 cyl. engine is such that they really turn over some RPMs at speed. The number you quoted seems right to me. I don't have a tach in my car so I can't give you comparable readings but have seen the spec for RPMs at 60 mph - about 3,200. Mine sounds like it needs another gear - 5th - at cruising speed.
Sounds like you have a really cherry car. Mine is in the same condition but with a few more miles. Yours should perform better with fuel injection and the 230E does have a few more HP than my 230 carb version - about 20 more HP, IIRC. In the U.S., the 230s were not very common and only offered for 2 yrs. Most 123s in the U.S. were either 4 or 5 cyl.diesel or 6 cyl. gas. This makes my car a little more rare here. Mine was owned by a close friend and in all the years I have known this car I have only seen a few of them on the roads. I believe the 230E was more common in other parts of the world.
oliverb is offline
post #3 of 6 (permalink) Old 05-25-2009, 10:05 AM Thread Starter
thank you very much. Sounds like its fine then.
post #4 of 6 (permalink) Old 05-26-2009, 09:29 AM
Date registered: May 2005
Vehicle: '07 GL320CDI
These 4-speeds normally start from a stop in 2 unless you really floor it or select manually.
The old Switzerland pull a house trailer up a hill from a stop test.
Kent Christensen
'07 GL320CDI
lkchris is offline
post #5 of 6 (permalink) Old 05-26-2009, 11:06 AM
Kajtek1's Avatar
Quoted: 1058 Post(s)
Side topic about color. I used to own W123 in off white. The official name of color was "Bamboo"
The color description nobody could understand.
Few pictures here would be priceless.
Kajtek1 is offline
post #6 of 6 (permalink) Old 05-26-2009, 03:54 PM Thread Starter
will take some pictures tomorrow and post them for you.
    7 speed auto gearbox ATF change keyhole C209/A209 CLK-Class 74 05-27-2014 01:19 PM
    W123 manual gearbox oil? 5 speed 100haggis W123 E,CE,D,CD,TD,TE Class 14 04-07-2009 06:39 AM
    did w123 had automactic 5 speed gearbox????? harpreet928 W123 E,CE,D,CD,TD,TE Class 20 01-25-2009 01:39 AM
    350sl/450 Auto Gearbox Question 3 Speed? Peter Seow R/C107 SL/SLC Class 10 08-19-2006 10:45 PM
    5 speed auto gearbox in a ce Guest (MBNZ) W124 E,CE,D,TD Class 2 09-06-2001 05:48 AM
