Recharging E320 Battery - Mercedes-Benz Forum
post #1 of 8 (permalink) Old 05-24-2009, 09:10 AM Thread Starter
Date registered: May 2009
Hi,
I was on an extended vacation and on return I got a "dead battery" in my E320 (2004). The E320 battery is in trunk and I could not open the trunk as the latch to open the trunk won't work (without the battery). I could not find any other way to open the trunk. There must be some other way to open it!! Any help will be highly appreciated.
Thanks.
mita2009 is offline
post #2 of 8 (permalink) Old 05-24-2009, 09:31 AM
Date registered: Dec 2002
Vehicle: 92 500SEL to 01 E320T and others
I thought the late model "E"s had a +stud in the engine compartment, did they take the battery out of under the rear seat?
Call 1800 for Mercedes the jump is free, they will sell you a battery but dont pay more than $150 or so.
Peter Guenther is offline
post #3 of 8 (permalink) Old 05-24-2009, 09:36 AM
Diesel Benz's Avatar
Quoted: 37 Post(s)
Why did you not open the trunk with your metal key? Is the car manual in the trunk too?
Diesel Benz is offline
post #4 of 8 (permalink) Old 05-24-2009, 10:25 AM Thread Starter
Thank you to both of you - Diesel and Peter. I did not check under the seat and don't remember seeing the + stud under the hood again. I will check both now.
Hope I find the +stud!!
BTW: I don't have a metal key - all I have was electronic keys...
Thanks again.
mita2009 is offline
post #5 of 8 (permalink) Old 05-24-2009, 11:36 AM
keyhole's Avatar
Date registered: Sep 2006
Vehicle: 2004 CLK 240 Coupe
Quoted: 385 Post(s)
Thanks again.
Are you sure about that?
If your key looks like this, you have a mechanical key hidden inside it. Slide the release button (5) sideways, and the mechanical key (7) will pull out. Neat eh?
keyhole is offline
post #6 of 8 (permalink) Old 05-24-2009, 03:37 PM Thread Starter
Thanks Keyhole. I did jump start. :-)
mita2009 is offline
post #7 of 8 (permalink) Old 05-24-2009, 09:55 PM
Date registered: May 2005
Vehicle: '07 GL320CDI
Quoted: 2 Post(s)
Plus, you learned you have metal key!
Kent Christensen
Albuquerque
'07 GL320CDI
lkchris is offline
post #8 of 8 (permalink) Old 05-25-2009, 05:55 AM
Date registered: Jan 2004
Quoted: 30 Post(s)
Now if you could only remember where you put your owner's manual.
Len
sokoloff is offline
    Recharging Freeon osdesierto W202 C-Class 0 05-29-2008 03:15 PM
    AC recharging question...... gcinque W123 E,CE,D,CD,TD,TE Class 3 07-10-2007 07:11 AM
    Recharging my own AC? Goldenvoice W123 E,CE,D,CD,TD,TE Class 1 06-14-2007 12:10 PM
    Freon Recharging lpaddikt General Mercedes-Benz 7 07-15-2005 12:44 AM
    help on recharging ac 430 ml slvr430ml W163 M-Class 11 09-10-2004 07:14 AM
