Steering problems - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 05-21-2009, 04:36 PM Thread Starter
dore_ionescu's Avatar
Date registered: Feb 2009
Vehicle: MB 300SD, 1981, W126
Post Steering problems
I need some information.
I bought a MB 300sd '81 w126, and I want to know if it is normal when I turn right at the maximum to be shorter than in left. I given the explanation that left turns are closer and often to do. I consider it would be ok for the left turn up to be like turning up right. When the wheels are straight as the wheel is. I have problems to turn right on parking lot .
Thank you.
dore_ionescu is offline
post #2 of 4 (permalink) Old 05-22-2009, 08:15 AM
Date registered: Mar 2009
Vehicle: 1990 300SEL, 2004 Cad. Escalade
Steering should have roughly the same turns both ways. The steering gearbox most likley was installed incorrectly at some point, then aligned to get the steering wheel to lock at center so the turn signals will cancel correctly. Hard to turn one way when the car is not moving is most likely a broken spring in the reaction valve inside the gearbox. If that is the case when you replace the gearbox and inastall it right it should solve both issues. My name is Chris Brown I own C & M Hayraulics, we have been in bus. since 1994 and all we do is remanufacture MBZ power steering gearboxes, p/s pumps, and air (smog) pumps with electro-magnetic clutches. We only deal with the larger aftermarket parts dist.. however most online dist. can get our parts if you ask. I'm happy to answer any questions you may have, give me a call. 702.734.8090
thegearboxguy is offline
post #3 of 4 (permalink) Old 08-15-2009, 07:41 AM
leapyfish's Avatar
Date registered: Apr 2008
Vehicle: 1998 SLK230 199,xxx Miles
Quoted: 4 Post(s)
leapyfish is offline
post #4 of 4 (permalink) Old 02-08-2010, 04:26 PM
Date registered: Oct 2007
1992 mbz 500 sel steering wheel,side and rear view mirror does not work @ when it rains
showmdbenz is offline
    Steering problems cclake R/C107 SL/SLC Class 8 09-01-2008 08:36 PM
    Steering Problems merco1 V-Class 10 11-28-2007 01:53 PM
    steering problems kashyx W211 E-Class 2 05-28-2007 10:38 PM
    Steering problems Ratso W163 M-Class 19 01-16-2004 06:52 PM
    steering problems sjtymko G-Class 12 02-24-2003 08:00 PM
