W463 Who knows how to check vaccum leak - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 05-21-2009, 04:04 PM Thread Starter
jakub.baraniak's Avatar
Date registered: Sep 2008
Vehicle: 126 85 300sd, 124 300e, 116 78 450 sel, 126C 85 500 sec, 02 g 500
Unhappy W463 Who knows how to check vaccum leak
does anybody knows how to find vaccum leak, on 2002 5.0L .I have everything changed from sparks,fuel filter,injectors cleaned ect. to comp. diagnostic. show no resoult for my random shakes , It has to be vaccum leak but were?
G500 02' 79 000 miles
jakub.baraniak is offline
post #2 of 2 (permalink) Old 05-23-2009, 04:45 PM
Date registered: May 2009
Vehicle: 85 Mercedes Benz 380SE, 04 Jaguar XJ8, 76 Rolls Royce Silver Shadow, 95 Mercury Sable wagon
A vacuum leak is certainly suspicious, however, you must make sure there is a leak. What is the vacuum reading at idle? If you are seeing <20 in-hg vacuum, there is probably a leak, like a cracked line. Just remember, patience will find it.
curtesy is offline
    Rough Idle / Vaccum Leak after EGR tube removal and cleaning pcy W163 M-Class 20 12-25-2008 09:46 PM
    1983 w123 300D HUGE vaccum leak DSLVO W123 E,CE,D,CD,TD,TE Class 3 01-23-2008 01:59 AM
    Vaccum leak at trunk lock gasket cornpone W126 S,SE,SEC,SEL,SD,SDL Class 4 03-03-2007 08:25 PM
    Automatic Transmission or Vaccum leak StarGazer W201 190-Class 1 07-15-2006 03:34 AM
    HELP!! vaccum leak...bad engine shake [v] lushansilva W126 S,SE,SEC,SEL,SD,SDL Class 10 09-29-2004 01:54 PM
