1994 E320 IDLE PROBLEM - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 05-21-2009, 10:31 AM Thread Starter
Date registered: Jul 2008
Hi All
In new to this forum so please help if you can.
My '94 E320 is experiencing some idling problems when I start the vehicle. It will start fine, then the rpm will fluctuate between 1200 and 100 before the car dies. After the car warms up, it usually does not happen. I was told by a mechanic that either the air flow sensor is malfunctioning or i will need to replace the entire wiring harness. Is anybody experiencing a similar problem? anything that has worked to fix this problem? please advise ...thanks!
emeryville felix is offline
post #2 of 2 (permalink) Old 05-24-2009, 01:42 PM
Date registered: Nov 2008
I had a similar, or maybe even the same, problem with my '94 e320. the rmp fluctuated for a while but my car wouldnt die after. It seemed to happen less when the car was warmed up, but it still happened frequently. Anyway, at first my mechanic thought it was the air flow sensor, but it ended up being that and the spark plugs as well.
Hope i helped good luck.
lorenzoinabenzo is offline
    1994 e320 idle lebstyle007 W124 E,CE,D,TD Class 11 02-06-2008 01:56 PM
    1994 e320 idle lebstyle007 General Mercedes-Benz 1 10-10-2007 09:56 PM
    1994 E320 AC problem... 2005x W124 E,CE,D,TD Class 6 08-17-2007 04:33 AM
    Problem with my 1994 E320 rostov W124 E,CE,D,TD Class 3 05-20-2004 08:11 PM
    TRANSMISSION PROBLEM E320 1994 Guest (MBNZ) W124 E,CE,D,TD Class 2 12-22-2001 11:57 AM
