CLK 350 2008 PLEASE HELP - Mercedes-Benz Forum
post #1 of 6 (permalink) Old 05-21-2009, 06:42 AM Thread Starter
Date registered: May 2009
Question CLK 350 2008 PLEASE HELP
Hi
I purchased a CLK 350 recently. I have discovered that the right rear indicator lamp, right rear reverse lamp, the brake lights and the indicator lamps on the xenon headlights are not operational.
Please help, i have been told that it may be the cem unit or something like that.
What could be the problem?
Isaa is offline
post #2 of 6 (permalink) Old 05-21-2009, 08:08 AM
Diesel Benz's Avatar
Quoted: 37 Post(s)
Perhaps you are referring to the rear SAM. It does drive most of the lights but the front indicators are driven by the front SAM. In any case this should not happen on a 2008 car, is this a flooded one or from an accident? Is it not covered by warranty?
You could have a look at the rear SAM if it is clean. Sometimes water may enter the car interior and spoil control units. The best would be to diagnose the car with Star, easier to figure out what actually is wrong.
Diesel Benz is online now
post #3 of 6 (permalink) Old 05-21-2009, 11:25 PM Thread Starter
The car was involved in an accident on the right side damaging the door and rear 'fender' causing the door, roof and rear airbag to 'pop'. The accident was not that major. However the rear SAM is on the opposite side and the accident never touched the front SAM. So warranty wont cover.
Also what is baffling is that the only things not working are the front indicators and the right rear one also the brake lights flash when you depress the brakes. The brake light on the boot functions normally. The mirror indicator lamps and the left rear function normally and the xenons funtion normally. No other electronic problems.
I cant see that the SAM is damaged but....
Had the car at Mercedes dealership and the diagnostic there does not find any faults with the lamps. The onboard diagnostic also shows nothing.
What is star?
Isaa is offline
post #4 of 6 (permalink) Old 05-22-2009, 05:57 AM
Quoted: 37 Post(s)
What is star?
Do you mean the brake lights come on for a short period when you press the brake pedal and then go away (except that the centre light remains on)? All lights are controlled via the CAN bus except that brake lights have in addition a direct control wire (to reduce switch on delay and for redundancy). I still don't see how the rear brake lights would reach the "on"-message but would loose it quickly.
The only common thing with the rest of the rear lights and the front indicators is basically the CAN BUS (of course the combination switch and the steering column control module).
Star is the MB diagnosis computer (SDS, DAS software or what ever one wants to call it). I wonder if the workshop only checked light faults or was Star claiming everything else being fine too.
I don't see a lot of options without SDS, you could check the wiring carefully, not just visually but measure end-to-end contact and no contact to ground and other wires. You could also detach the supply wire from the SAM and try if the corresponding light comes on. Check the lamp assembly grounding too.
The car has a few pyro-fuses but I cannot see that being an issue when some parts that are driven by the SAM still work fine.
post #5 of 6 (permalink) Old 05-22-2009, 07:30 AM Thread Starter
No, the brake lights flash intermittently like the flashers except the boot stays on. I cant see how the SAM can be a problem coz logic tells me that the front and back lights have different SAMs right?
This is a strange one.... I am at a loss.
Isaa is offline
post #6 of 6 (permalink) Old 05-22-2009, 06:19 PM
DirectLA's Avatar
Date registered: Jan 2007
Quoted: 8 Post(s)
Forgive me if I'm misunderstanding but if the accident didn't damage the SAM then it should be covered by the warranty since there is no abnormal damage. If it were part of an accident damaged part then I would agree that it's not a manufacturer issue but you stated the opposite.
-Marrs
The Coupe Group on Facebook
DirectLA is offline
    2008 CLK 350 after market audio installation 08CLKguy Audio & Telematics Forum 2 04-06-2010 08:39 PM
    2008 CLK 350 CAB BREEZY 350 C209/A209 CLK-Class 1 10-29-2008 08:02 PM
    Advise Needed: New 2008 CLK 350 Owner MsCLK350Benz08 C209/A209 CLK-Class 0 09-14-2008 07:46 AM
    2008 e 350 jaymoney92 W211 E-Class 0 08-30-2007 06:02 PM
    WTB: w209 navigation unit, taillights for clk 350, front bumper from clk500/350/amg ekohan For Sale/Wanted/Trade/Giveaway 0 12-22-2006 03:53 AM
