Cluster replacement on 190, now get slack? - Mercedes-Benz Forum
post #1 of 6 (permalink) Old 05-20-2009, 06:54 PM Thread Starter
Date registered: May 2009
Hi,
Want to revive my odometer on 190E 2.6 1989...
Anybody know how to get slack on speedo cable to get enough access for back of the cluster.
It goes inside from motor comprtmt directly, not on the floor insidelike on other model where you can just unclip it.
Should I go under ? Hope no.
Danke to all
Dai
dainova is offline
post #2 of 6 (permalink) Old 05-20-2009, 08:32 PM
peoples28's Avatar
Date registered: Nov 2006
yea i believe all 190s have the bolt (i think 10mm) on the side of the transmission. I know thats how i had to get mine out
There Are Only Two Tragedies in Life: One Is Not Getting What One Wants, and the Other Is Getting It. -Oscar Wilde
peoples28 is offline
post #3 of 6 (permalink) Old 05-21-2009, 10:11 AM
MTI
MTI's Avatar
Vehicle: '85 2.3-16 '99 C280 '11 GLK350
While you could get under the car and disconnect the speedo cable from the transmission, it is also possible to get the cluster out as follows:
Remove the underdash panels which is held in by screws
Remove the black plastic air ducting that runs from the center console to the left vent which is held in place only by pressure fit
That will clear enough space to get your fingers on the brass colored speedo cable nut on the back of the cluster. Loosen and then push the cluster out from the back. There is enough slack in the cable harness to angle the cluster out without moving the steering wheel.
MTI is offline
post #4 of 6 (permalink) Old 05-21-2009, 11:25 AM Thread Starter
Thanks to People28 and Honolulu!
will try#2.
Dai
dainova is offline
post #5 of 6 (permalink) Old 05-21-2009, 02:08 PM
MTI
MTI's Avatar
I re-read my post and should note that you only have to undo the underdash panel on the driver's side.
Removing the air duct may seem dangerous, but being press fit into each end, it is literally a tug and pull operation. The flexible duct is wiggled out from under the dash.
When you're looking up at the back of the speedo, shine a light towards the center and you'll easily see the brass knurled fitting.
All the wire harnesses on the cluster are key coded, so you really can't plug one into the wrong location.
When handling the cluster, be careful about the solder joint that creates the "ground/earth" connection between the center and left modules. If you find that the left side (gas, engine temp, oil pressure) goes dead, it's quite likely that the joint was broken.
Finally, before re-assembly, go ahead and replace all the $1 light bulbs and then you'll be good to go for another 10 years.
MTI is offline
post #6 of 6 (permalink) Old 05-26-2009, 06:42 PM Thread Starter
MTI:
Hi, tried to get to speedo from inside and could not, removed protective foam bar and then disconnected vent tube and still could not see/access speedo nut. there is some triangle reinforcement plate that prevent to do this.
Did you mean exactly 190 model?
I did disconnect speedo using screwdriver in the small opening I got, just because nut was loose enough to do so, but i can't do this putting it back.
So now I'm looking to disconnect cable on transmission.
tx
dai
dainova is offline
    190 D rocker panel replacement??? tryagn5 W201 190-Class 7 11-15-2010 03:52 PM
    Question about cluster replacement bperry W220 S-Class 7 05-18-2008 07:08 PM
    Replacement instrument cluster 560DBleu W140 S-Class 1 03-20-2007 05:31 AM
    Instrument Cluster Replacement leeah W210 E-Class 10 02-06-2007 06:23 PM
    cluster bulb replacement. osdesierto R170 SLK-Class 1 03-02-2006 01:05 PM
