2001 S500 Idle Question - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 05-18-2009, 10:05 PM Thread Starter
Date registered: May 2009
First Benz. Just bought 2001 S500 which had CEL on and rough idle. They replaced the MAF with new one and the CEL is now off but it still has a rough idle. Not terrible but not great. Two questions. Any idea on what is the cause of the rough idle is and second would the CEL codes still be in memory? The mechanic did disconnect the battery when he installed the new MAF erasing the codes???
Any help or suggestions are appreciated. Aloha
mauiman525 is offline
post #2 of 3 (permalink) Old 05-20-2009, 05:04 PM
Post I have a 01 C240
I am also having the rough idle problem, and also lack of power off the line. I havent come to an exact remedy but have been told to look at a few things:
Resistance in the coil pack/wires on the cylinder that is misfiring/idling rough.
Fuel Filter could be bad
Catalytic Converter could be plugged
Spark plugs need to be changed or a tune up.
If any of these works let me know so I can do the same. I will do the same
Nate
nct91f@gmail.com
nct91f is offline
post #3 of 3 (permalink) Old 05-20-2009, 07:13 PM
Musikmann's Avatar
Quoted: 6 Post(s)
I don't think disconnecting the battery will erase stored error codes. As I understand it, some can be cleared using commercially available OBDII scanners but others require the SDS system or something else pretty sophisticated like Carsoft.
Musikmann is offline
    2001 s500 navigation cd-maps question!,, bosanci28 W220 S-Class 4 07-27-2008 10:16 PM
    idle s500 2003 vinces W220 S-Class 1 09-03-2007 05:17 PM
    2003 s500 idle vinces W220 S-Class 0 08-16-2007 07:33 AM
    2001 S500 headlight upgrade install question yungreek 500 W220 S-Class 1 01-13-2007 02:53 PM
    question on my 2001 s500 mwang218 W220 S-Class 0 01-28-2004 11:31 AM
