heat and air problem - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 05-18-2009, 08:47 AM Thread Starter
Date registered: May 2009
Vehicle: 2002 M-class ML 320
I bought my second hand 2002 M-class about 2 months ago. Soon after I noticed a chemical smell when the air was on, so I shut it off. Since it was cool out, I drove without AC for awhile. Then when I tried to turn it back on it it didn't work. The compressor does not come on and the windshield and center vents don't blow any air. The side and floors vents work fine. Today I tried to run the heat and it doesn't work either.
I took it back to the dealership where I bought it (Honda/Acura) and they were3 clueless. Before I take it to the MB dealer for repair I wanted to get an idea of what I might be looking at; i.e does this sound like it only needs refrigerant or is a vehicle of this age likely to need a major repair? And in both cases what kind of costs should I expect?
Any tips would be helpful.
Joy Allen is offline
post #2 of 4 (permalink) Old 05-18-2009, 10:19 AM
Check Codes's Avatar
Vehicle: '01-E320 & 02-ST2
Quoted: 35 Post(s)
Hi, Joy, welcome to the forum.
Please click the User CP link and complete your BW profile for vehicle and location as that is often useful information, then it's in every post. And re: location often another member will be able to recommend a decent shop near you.
There is a forum that is specific to your SUV and it is the W-163 forum. If you scroll down the main page you will find it and if you post in there you're more likely to get answers that are specific to your vehicle. The general forum is more for things of interest to all MBs.
The chemical smell may just be dirty cabin filters, yours may also have the charcoal ones. Replacing those will usually clear that up.
On many models the air direction is controlled by vacuum, so it could be something that simple. When you say it "doesn't work" you only mean the air direction, right? You get cold air on AC and hot air, but only from the side and floor vents? Those are entirely different problems, so it's important to be precise on an internet forum.
At any rate, post with a bit more detail into the 163 section and they'll point you in the right direction.
Take care and enjoy the ride,
Check Codes is offline
post #3 of 4 (permalink) Old 05-18-2009, 11:34 AM
Michael Pillay's Avatar
Date registered: Oct 2003
Quoted: 78 Post(s)
Michael Pillay is offline
post #4 of 4 (permalink) Old 05-18-2009, 03:29 PM Thread Starter
Thanks for welcoming me to the forum and for the tips on using it. I will post my inquiry where you suggested and I will be more clear in describing the problem.
    Oh boy, Air flow problem (A/C,heat) ghost W140 S-Class 11 10-02-2009 03:05 PM
    Air Condition/Heat Problem shadwick W220 S-Class 6 03-03-2008 08:34 AM
    No heat or air R22Flyer R170 SLK-Class 5 02-02-2008 07:01 PM
    Air and heat DW140 W140 S-Class 2 08-28-2006 01:38 AM
    no more heat, a/c, or air lyrics10 W126 S,SE,SEC,SEL,SD,SDL Class 7 04-15-2005 08:33 PM
