1986 300e danny kaye's old car - Mercedes-Benz Forum
post #1 of 9 (permalink) Old 05-17-2009, 12:58 AM Thread Starter
Date registered: May 2009
Vehicle: 1986 300e 238,000 Danny Kaye original owner
91 n.y.other cars 1983 320i 1995 540i 1986 240 volvo 66imperial 67 new yorker 91new.yorker 96 960volvo
melik is offline
post #2 of 9 (permalink) Old 05-17-2009, 06:38 AM
Date registered: Oct 2007
Vehicle: 2002 SLK 230 1986 560SL 2008 Honda CRV
Welcome to Benzworld
livefreeordie is offline
post #3 of 9 (permalink) Old 05-17-2009, 02:42 PM Thread Starter
1986 300e won't start
started to stall after a few short runs, restarted and now won't start at all.
200k miles...I get a spark to the plugs and replaced them anyway...I replaced fuel pumpand filter 3 years ago. When installed 3 years ago, i checked fuel delivery problem by a short spray of starting fluid while cranking and it ran so i quickly isolated a faulty fuel pump(also didn't hear initial buzz and it responded to a slight tap of hammer). I don't understand why i can't get the car to start when i have spark and i am introducing fuel via throttle passage!
I've checked the hoses of the idle control valve, vacuum line to EZL, i've checked OVP fuse, jostled the fuel pump relay(though the starter fluid should circumvent that for testing, right?) i don't want to throw parts, including an EZl (008 545 16 32, right?) at this car. is there a diy code reader for this pre obd II car.? I replaced cap and rotor last year Even with a bad crankshaft sensor or wire, shouldn't i get a rough start? any help thanks
melik is offline
post #4 of 9 (permalink) Old 05-17-2009, 03:34 PM
Always Remembered RIP
cascade's Avatar
Date registered: Nov 2006
Vehicle: 1991 560SEC AMG
Location: Grass Valley, N. Calif. / Gardnerville, Nevada
Quoted: 17 Post(s)
Send a message via AIM to cascade
Post
Welcome aboard, do you have pictures of your celebrity owned car to share?
You can get quick answer to the question(s) relating to your sedan if you repost this one, into the W124 section!!
Thanks for signing on!!!
Jim
<--- superschnelle 300 hp 10:1 ECE euro HV, Hochverdichtung = high compression (11/2011) ... Wie im Freien Fall. Nur horizontal.
"I swear to god, it's like I live in a trailer of common sense, and stare out the window at a tornado of stupidity." >'='<
cascade is offline
post #5 of 9 (permalink) Old 05-17-2009, 07:57 PM Thread Starter
thanks for your welcome: how can i send my post to the w124 forum? since i couldn't start it, i repaired door hinge restraints and other jobs helped by saving parts i picked up at the junk/treasure yards. your views on the starter fluid failure? melik in eagle rock, california
melik is offline
post #6 of 9 (permalink) Old 05-17-2009, 10:31 PM
cascade's Avatar
Quoted: 17 Post(s)
Not exactly sure what you mean about starting fluid, though. Never even heard of it, and so I don't know the answer.
My Mercedes' 90 and 91 have them just inboard of the right rear wheel, the fuel pumps. Are yours there?
Anyway here is where to ask:
W124 E,CE,D,TD Class - Benzworld.org - Mercedes Benz Discussion Forum
You have a W124, and these guys would know.
If you give up right near you is the awesomest mechanic for the older Mercedes in the Valley, and VERY good rates.
Mr MB at 5557A Reseda, off the 101 in Tarzana. Name is Enrique Rodriguez, working on these cars since 1961.
I used him many times, he is great and I and many others here highly recommend him.
I like Eagle Rock a lot, Oxy College is up there isn't it?
They used to have a Chevy place there called Will Newman's Citizen Chevrolet, didnt they?
Very partial to the Volvos like you had, I actually almost bought a new 96 960 was on the basis of my excellent 740 1991 sedan. But a 2nd hand 1991 SEC560 black coupe that I still have got the $38,000 the 960 wouold have cost, the old 960 and the later S90 the LAST of the good RWD Volvos. Good looking too. The 240 is the eternal "brick". That and the 740 "look like the box they came in" LOL
66 IMPERIAL that is a real US luxo barge, impressive. Finest and most luxurious Chrysler they ever made thaqt decade. Wonderful with a 440 in there.
Jim
cascade is offline
post #7 of 9 (permalink) Old 05-28-2009, 10:05 PM Thread Starter
i know reseda blvd real well and will check out mr. MB. what i meant with starter fluid, was to see if there was a fuel delivery problem, you spray a second or two of the stuff in the intake manifold, if you have electrical ignition intact, the motor should run until the limited fuel burns off... btw, i piggybacked a test ignition module, and the care still did not start...so, i will try the crankshaft sensor on the flywheel(also called a reference sensor on the flywheel) and see if that's the problem with the no start..this weekend. melik thanks for any help or comments
melik is offline
post #8 of 9 (permalink) Old 05-29-2009, 01:05 AM
GogglesPisano764's Avatar
Date registered: Feb 2008
Vehicle: 1983 300D Turbo Diesel
Send a message via Yahoo to GogglesPisano764
Welcome to Benzworld!
Yes Honey! Thats how they sound! Its a diesel!
MBCA Member
1983 300D "Schultz" (Relocated to Canada)
1983 300D "Klaudia" (My new love)
1985 300D (Whipped then Stripped)
1985 300SD (In way over my head and let go)
2002 Suburban Z71 (Eats gas stations during trips)
2004 Aveo (Only because I enjoy stuffing my fat ass in a tiny car. Oh and it gets good gas mileage)
GogglesPisano764 is offline
post #9 of 9 (permalink) Old 05-30-2009, 05:12 PM Thread Starter
a mechanic at the junkyard suggested i check out the rotor/distrib on the car despite replacing it 2 years ago?(i thought they last longer) any way the rotor/distrib were burnt up, replaced them courtesy autozone down the street and the car fired up immediately. learned a lesson, check gas, plugs, fuses, rotor/distrib if applicable, then relays, air etc. my mistake was not to bother checking out the rotor distrib, thinking it was still "new" after two years.... do these things last only a short time, even on electronic systems.. 60's cars needed plugs, rotors,etc. replaced yearly, that's why many have gone to electronic ignition...thanks everyone melik until the next proble.
melik is offline
    1986 300e autoworrks320 For Sale/Wanted/Trade/Giveaway 5 10-08-2008 05:43 PM
    1986 300e westcdn300ebenzguy For Sale/Wanted/Trade/Giveaway 0 01-23-2008 09:33 PM
    1986 300E FIVE SPEED parts car for sale venableb W124 E,CE,D,TD Class 0 12-07-2007 06:15 PM
    1986 300E FIVE SPEED manual parts car venableb For Sale/Wanted/Trade/Giveaway 0 12-07-2007 06:01 PM
    1986 300E GHM W124 E,CE,D,TD Class 3 07-16-2005 08:07 PM
