Noise from rear end - 2001 C Class Estate - Mercedes-Benz Forum
post #1 of 1 (permalink) Old 05-14-2009, 03:12 PM Thread Starter
Date registered: May 2009
Vehicle: C Class 220 CDI estate
Post Noise from rear end - 2001 C Class Estate
Hi - Mercedes C220 CDi estate 2001 W203 - noise at the back end sounds like very distant thunder or heavy planks of wood thumping together in the back. Occurs when driving low to moderate speed and going over bumps on road - happens just after the bump not at exactly the same time. Not so noticeable at speed or big bumps on road Any ideas? Many thanks, John
southerly95 is offline
    Humpty Dumpty from the rear end (rear end noise) hsahai W126 S,SE,SEC,SEL,SD,SDL Class 2 03-25-2009 11:03 AM
    E320 CDI estate 2001 avantgarde..thumping noise r11pak General Mercedes-Benz 2 12-15-2008 12:33 PM
    Noise from rear end? JayFromOz W126 S,SE,SEC,SEL,SD,SDL Class 9 07-02-2008 04:49 AM
    Rear end noise when break after starting/cold; wind noise from driver side window. zhuorongdeng W203 C-Class 1 07-03-2007 01:59 PM
    Can I use AMG 17inch alloy wheels from a 1996 E Class 320 Cabriolat on a 2001 E-Class Estate NZ Kiwi W210 E50 AMG, E55 AMG 1 02-15-2004 03:00 PM
