240D Fuel Sending Unit --- HELP! - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 05-11-2009, 09:21 AM Thread Starter
Date registered: Dec 2008
Quoted: 2 Post(s)
Question 240D Fuel Sending Unit --- HELP!
I finally got around to taking out my old sending unit that was no longer working to see what might be the problem. Per the great tips provided on this forum, I disassembled the unit and found that sludge/grime build-up had indeed rendered this unit non functional.
I carefully removed all sludge and cleaned the unit thoroughly.
I inadvertantly snapped one of the guide wires/electrical wire connections (brass wire) that runs the length of the unit top to bottom. I had a friend reattach/resolder this wire back to its original connection at top of unit. It was now locked and ready to install. It almost looked brand new.
The one issue I had before reinstalling this unit was the fact that rust and pitting had settled onto the chrome shaft at both the top and bottom of the shaft that might impair the working of the float (ability to freely move up and down with fuel levels). I did a cursory job of sanding these areas on the shaft but not a complete job. By the time I had noticed this, I had already reattached/affixed the electrical connections on the unit; and this left little space to work in to do more sanding/polishing without breaking these wires once again.
To my dismay, the sending unit works sporadically now...not like new as advertised. It sometimes registers a current to the fuel gauge and it sometimes does not. And if it registers a fuel level at all, it only moves up to the 1/4 tank level even though the fuel tank is full.
Does anybody have any ideas on what I might have done wrong, or what might be causing this all to happen? Before I took unit out, it was permanently recording a FULL TANK (I suppose the float was stuck at this level permanently due to sludge build-up).
While this turned out to be a much easier job than I thought it would be, I've ended up with BUPKUS on this front.
teddyd49 is offline
post #2 of 3 (permalink) Old 05-11-2009, 09:41 AM
Musikmann's Avatar
Quoted: 6 Post(s)
Your chances of getting a quick response will be better if you post this again on the forum specific to your car. Just scroll down from here and you will see it. Good luck.
Musikmann is offline
post #3 of 3 (permalink) Old 05-11-2009, 10:00 AM Thread Starter
Quoted: 2 Post(s)
Thanks..have re-posted on 123 Chassis thread....cheers
teddyd49 is offline
The Ultimate Solution to the Fuel Gauge/Fuel Sending Unit Problem jengel111 W163 M-Class 4 03-10-2013 11:22 AM
Fuel sending unit ?? unlukky C208/A208 CLK-Class 13 02-18-2010 02:40 AM
1982 240D Fuel Sending Unit Location fourleggedcouch W123 E,CE,D,CD,TD,TE Class 8 02-24-2009 08:00 PM
Fuel Sending unit... JBowers W126 S,SE,SEC,SEL,SD,SDL Class 6 12-11-2008 04:41 PM
fuel sending unit 1982 240D oldcarpappy W123 E,CE,D,CD,TD,TE Class 3 09-08-2005 05:53 AM
