HELP!!!! Any suggestions? Thank you! - Mercedes-Benz Forum
post #1 of 5 (permalink) Old 05-10-2009, 12:10 PM Thread Starter
Date registered: May 2009
Can anyone help me out? About 2 months ago, the "engine check" came on and the car started running strange. It wouldn't start correctly, sometimes not at all. The engine would turn but not turn over. So I purchased a code machine, in hopes of finding out what was wrong, the cheap way. It came up with a "throttle position sensor" and a "camshaft position sensor". I took it to benz, they claimed it was not the throttle position sensor but just the camshaft position sensor. After finding out the cost, I purchased it online and took it to pepboys. They fix it, runs okay but now starts to rev certain times and other times there wouldn't be enough gas it seemed and the car would rev too low, but not die, just start shaking at a very, very low idle. Not to mention, the camshaft position sensor is still on when I use the code machine. Anyway, I bring it back to benz, this time they claim it's the "air flow mass sensor". Fine, brought it home, ordered the part online and did it myself this time (they wanted $700 or so, I did it for $55 plus a set of polygonal tamper proof wrenches). Now, the engine light goes off, BUT it still is idling strangly. So here I am, 2 sensors fixed (camshaft position sensor and MAF) and now I'm thinking it's the oxygen sensors. By the way, the "check engine" light was off for about 5 days, then it came back on. Did I hurt the new "air mass sensor" by not fixing the oxygen sensors I wonder? Or is it even the oxygen sensors? When I hook up that machine, I get a bunch of code readings, all the same for the most part. They read:
bank 1 and 2 too rich and too lean.
What would cause the banks to run lean/rich? Obviously the low idling or too high of idling is being caused by too much gas or too little or too much air or too little, which makes sense as it correlates with the "bank 1 and 2 too rich and too lean" message.
Anyone? Thanks!
enap66 is offline
post #2 of 5 (permalink) Old 05-10-2009, 01:42 PM
Musikmann's Avatar
Quoted: 6 Post(s)
A faulty oxygen sensor will make your car run too rich. I have no idea why it is too lean on one bank and too rich on the other.
Musikmann is offline
post #3 of 5 (permalink) Old 05-10-2009, 02:12 PM Thread Starter
Thanks for the reply. It's not too rich or lean in one or the other but in both. In other words, there are two banks. Bank 1 and Bank 2. The code reader comes up as bank 1 too rich, then comes up as too lean. Then the code reader comes up with Bank 2 too rich and then too lean.
Strange.... but I don't think it's the oxygen sensors, cause it makes sense that it would have to be all 4 of the oxygen sensors to be doing that. In other words, it must be 1 unit only since what are the odds of every oxygen sensor stop working at the same exact time? Nill if you ask me. But then again, I'm not a mechanic so.... Any other suggestions? And thanks again.
enap66 is offline
post #4 of 5 (permalink) Old 05-10-2009, 02:28 PM
Musikmann's Avatar
Quoted: 6 Post(s)
OK, thanks for explaining that further, I obviously mis-understood. My only further thoughts are concerning your scanner; are you sure it is giving you accurate readings? You might pop over to a PepBoys or Autozone and see what theirs says. I certainly agree that all 4 O2 sensors could not have failed at the same time. By the way, I am not a mechanic either. You're welcome and good luck.
post #5 of 5 (permalink) Old 05-10-2009, 05:50 PM
Michael Pillay's Avatar
Date registered: Oct 2003
Quoted: 91 Post(s)
It might help if you told us the year and model you have. There are subforums dedicated to different chassis. A search of that specific forum could help as well.
Mike
Michael Pillay is offline
    Need some suggestions bellagio W251 R-Class 2 06-05-2007 05:46 AM
    My Suggestions.... dantefr Benzworld Site issues forum 4 05-03-2006 03:12 PM
    need your suggestions BOY-6 W163 M-Class 25 12-15-2003 11:10 AM
    any suggestions about this??? jordan R170 SLK-Class 9 03-06-2002 09:55 AM
