W126 Timing Chain - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 05-09-2009, 05:03 AM Thread Starter
Date registered: Jan 2009
W126 Timing Chain
Hi folks, I am new to this site and it’s been a fantastic resource. I have a W126 380SE…love this car!. so decided to do a number of maintenance jobs starting with TIMINING CHAIN replacement. I performed the following steps;
1. Replaced all three chain rails, tensioner rail and tensioner
2. Rotated engine and everything aligned OK back to TDC
3. Connected new chain with old and preceded to feed the new chain.
4. During the process of disconnected old chain and to linkup the new chain things jumped a little so I then panicked.
5. BRAIN PHASE…In my stupidity I decided to rotate the left cam by three teeth to make the chain meet so I could connect it. Didn’t think to check alignment marks in relation to right cam…though everything apperaed OK
6. Started to rotate engine to see if all was OK and noticed that I couldn’t rotate any more.. and chain was very tight…PANIC
7. Backed of slightly (anticlockwise ….I know not a wise move but it was only a slight rotation)
8. Tried to then rotate clockwise again…STUPID I know…. I was thinking that the problem will go away!
9. Had a BREAK and time to think
10. Now that the chain was looser around Left cam sprocket, I disconnected the chain and rotated the cam back three teeth connected and everything aligned properly
All is well….I think!..My question to you guys is
1. Rotating the engine by hand when left cam is three teeth retarded (meaning that number 4 exhaust valves was hitting the piston) Has this caused damaged to this valve..I know it’s a merc and part are hard as nails but that crank has a fair amount of momentum even when rotating by hand. I was using my torque wrench to rotate the engine and noticed it did click at around 60Nm before I stopped
2. Secondly, rotating counterclockwise by say 10 degrees…can this cause any damage to anything ( I suspect bottom two rails ??)
Please someone put my mind at rest one way or the other
ozyjohnp is offline
post #2 of 4 (permalink) Old 05-09-2009, 05:19 AM
eric242340's Avatar
Quoted: 283 Post(s)
Hi and welcome to Benzworld. If you go to the bottom of the page and find Forum jump, then look for the 126 forum and re post this there OK
eric242340 is online now
post #3 of 4 (permalink) Old 05-09-2009, 05:37 AM Thread Starter
Thanks ERIC
ozyjohnp is offline
post #4 of 4 (permalink) Old 05-10-2009, 11:37 PM
GogglesPisano764's Avatar
Date registered: Feb 2008
Vehicle: 1983 300D Turbo Diesel
Send a message via Yahoo to GogglesPisano764
Welcome to Benzworld!! Hope you are able to fix your timing chain issue!
Yes Honey! Thats how they sound! Its a diesel!
MBCA Member
1983 300D "Schultz" (Relocated to Canada)
1983 300D "Klaudia" (My new love)
1985 300D (Whipped then Stripped)
1985 300SD (In way over my head and let go)
2002 Suburban Z71 (Eats gas stations during trips)
2004 Aveo (Only because I enjoy stuffing my fat ass in a tiny car. Oh and it gets good gas mileage)
GogglesPisano764 is offline
    IWIS timing chain compared to JWIS timing chain. ArkRoyal W126 S,SE,SEC,SEL,SD,SDL Class 5 07-01-2008 07:22 PM
    Timing Chain or Timing Belt on 230 Kompressor ? Bal C208/A208 CLK-Class 0 11-21-2005 01:08 PM
    W126 1983 300SD Timing Chain Tom Yaz W126 S,SE,SEC,SEL,SD,SDL Class 3 09-23-2005 03:37 PM
    Timing chain replacement/timing issue 1990 420SEL supersport6 W126 S,SE,SEC,SEL,SD,SDL Class 1 12-09-2003 02:03 PM
    Need Master link timing chain new or used for W126 380,500, 450, 560 should all be the same Guest (MBNZ) W126 S,SE,SEC,SEL,SD,SDL Class 0 11-01-2001 07:11 PM
