P0455 DTC on 01 S430 - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 05-05-2009, 08:43 PM Thread Starter
Date registered: May 2009
Question P0455 DTC on 01 S430
Hi everyone,
Working on a check engine light with a p0455 dtc. No need to explain the code as I am a 13 yr Master Tech. Just don't have a MB scan tool and smoke machine in my garage. Other than disconnected hoses, are there any other "common" issues generating this trouble code. Fuel cap and seal appear ok, can't smell fuel, or see any obvious hoses disconnected. Suspecting a vent valve/solenoid or purge valve issue but just doing off past experiences. Any one with insight on this issue??
Thanks in advance!
01Benzys430 is offline
post #2 of 3 (permalink) Old 05-05-2009, 10:09 PM
Check Codes's Avatar
Vehicle: '01-E320 & 02-ST2
Quoted: 35 Post(s)
MB's don't like to be topped off, the canister may be shot, but flip the gasket on the fuel cap and clean the purge valve, those are the most common for it. Have heard of the hose nipple cracking on the canister, so check that, although as you know usually you can smell fumes on that one.
Check Codes is offline
post #3 of 3 (permalink) Old 05-11-2009, 08:14 PM Thread Starter
Thank you for the input!
Anyone else have this issue and the repair??
    P0455 CEL light? 99 ML 99ML320_Benz W163 M-Class 17 03-21-2013 03:21 PM
    Code P0455 for 97 S420 aljabari W140 S-Class 7 08-03-2009 12:58 PM
    P0455 Mystery mneil R170 SLK-Class 19 04-29-2009 02:11 PM
    P1747 and P0455 Raxhi W202 C-Class 1 09-19-2008 03:36 AM
    OBD2 code P0455 Billy Bob R170 SLK-Class 10 05-14-2005 06:54 AM
