Replacement Key will not Start SL500 - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 05-05-2009, 06:31 PM Thread Starter
Date registered: May 2009
Hi folks, I have a 1997 SL500 Sport and recently bought a new master key. The old keys with the remote lock/unlock function both work in all doors and ignition but the new key will turn the engine over but will not allow it to start. Do I need to program the new key?
Thanks for any advise.
dcwebster1 is offline
post #2 of 4 (permalink) Old 05-06-2009, 08:24 AM
Date registered: May 2005
Vehicle: '07 GL320CDI
Replacement keys (that work) for Mercedes are only and exclusively available at Mercedes dealers. A nice protection for Mercedes owners.
Kent Christensen
'07 GL320CDI
lkchris is offline
post #3 of 4 (permalink) Old 05-06-2009, 09:59 AM
Musikmann's Avatar
Quoted: 5 Post(s)
Ditto to Kent, and if you bought your new key from a dealer it should already be programmed.
Musikmann is offline
post #4 of 4 (permalink) Old 05-06-2009, 10:00 AM Thread Starter
Kent, thank you for your reply. I guess I wasn't explicit, the valet replacement key was from MB dealer and they, at least the one tech. I spoke to, didn't understand why it unlock the doors, turned in the ignition and turns over starter but will not fire engine. The two Master Keys with the remotes work fine. I even thought maybe if I lock and unlocked the doors first with the valet key and then tried it in the ignition that might work but it didn't. Thanks for any additional insight.
    lost my key, key replacement cost? mbnz230 W140 S-Class 52 02-16-2016 05:33 AM
    1997 SL500 Key Fob Repair ahmorris R129 SL-Class 11 08-04-2008 03:23 PM
    sl500 cold start fine-short trip park restart rough idle hard start?? dpol1835 R129 SL-Class 7 01-02-2006 06:33 AM
    Sl500 headlight washers and stuck key kn90d3 R129 SL-Class 4 09-23-2004 06:58 AM
    SL500 Soft Top Removed Key While Lowering! snice R129 SL-Class 2 08-06-2003 08:25 AM
