Help!! 2002 C320...only blows heat at the feet! - Mercedes-Benz Forum
post #1 of 1 (permalink) Old 05-04-2009, 10:38 PM Thread Starter
Date registered: May 2009
Hello To All,
I'm a new guy here so be easy! Hah!..Found the site and had to join! I'm cruising today thru the neighborhood on a sunny Chicago day....and I go to turn the air on...why not..right..and the heat starts blowing directly at my feet, while turned to the upper vent setting on the climate control. I tried to adjust the temp setting and there was no change, as well as when I changed the vent directional setting..on the climate just continued to blow at the feet. And when the climate control is in the off position, it continues to lightly blow heat.
Its an 02 with 74000 miles and I have no idea what the issue maybe. I scheduled an appointment either way for Thursday at the dealer, but I figured why not ask fellow members for any advice or direction.
So if anyone has any ideas or advice....Thanks in advance!
ryanC320 is offline
    Heat blows cold out of drivers side vents Troyz R Us W203 C-Class 7 06-30-2009 04:33 PM
    1976 240d w115 heater fan blows...No heat! bigmelton2008 Vintage Mercedes-Benz 8 11-10-2008 05:44 AM
    No heat to feet ElvisH W140 S-Class 1 12-13-2006 06:04 PM
    93 190e AC is Cold, then blows hot, Heat blows hot, then cold hippiechick W201 190-Class 8 10-20-2005 11:35 AM
    Heat blows through the defroster - normal? bob98e320 W210 E-Class 2 10-03-2005 12:09 PM
