Help - Overfill = Leaky A/Transmission. - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 05-04-2009, 09:50 AM Thread Starter
Date registered: Mar 2009
Vehicle: 1995 SL320
Aarrggh! - had my A/Trans [ ‘95 all hydraulic '722.5' A/trans, behind a 3.2 liter Inline 6] at an indep. shop - just a filter change and partial fluid topoff. Shop overfilled it, and while driving home a motorist reported smoke coming out from underneath (result of A/T fluid leaking onto exhaust pipe). At home, I ‘extractor’ drained approx. 1.5 qts. out, to return to normal levels.
Back to the shop, they apologized, and checked the pan gasket was AOK. But now, I have a (previously tight, dry) trans. that leaks, spotting the floor. It’ll be back to the shop, but......did the overfill & 10 mile drive cause a seal or something to go??? What should I look for? And thanX for your input & help here!
willyinnv is offline
post #2 of 3 (permalink) Old 05-04-2009, 10:16 AM
Kajtek1's Avatar
Quoted: 1059 Post(s)
I had similar situation on W123. I just bought the car long drive from home and the seller overfilled the transmission. That didn't show up in city driving, till I hit freeway and at high speed the transmission boiled the fluid over the vent, while the fluid spilled over hot exhaust made 1/4 mile long cloud of heavy smog.
After checking what it was, I continued with no more incidents. To my knowledge W123 had open transmission vent. It is quite possible that your transmission has pressurized vent and the pressure damaged a seal in the process.
Good luck
Kajtek1 is online now
post #3 of 3 (permalink) Old 01-23-2011, 12:20 PM
Date registered: Sep 2008
i believe i overfilled my trans on an '81 300 td(turbo). does anyone know what the dipstick ought to read before restarting?
dayradebaugh is offline
    overfill oil? what happens? covinsky W210 E-Class 5 10-13-2008 10:17 PM
    Overfill Hubs Heavy Weapons Unimog 4 01-10-2008 03:21 PM
    what happens if you overfill the differentials? busoptr W163 M-Class 3 03-05-2007 05:00 PM
    Hard to pull transmission? Leaky 190D_iesel W201 190-Class 7 02-23-2007 11:06 PM
    fixing leaky transmission pan? 5000Kelvin W126 S,SE,SEC,SEL,SD,SDL Class 4 06-09-2003 04:33 AM
