Screw or allen wrench? - Mercedes-Benz Forum
post #1 of 11 (permalink) Old 05-02-2009, 04:06 PM Thread Starter
MiamiMarv's Avatar
Date registered: May 2009
which one do i use to take off horn cover on steering wheel.
MiamiMarv is offline
post #2 of 11 (permalink) Old 05-02-2009, 05:35 PM
Check Codes's Avatar
Vehicle: '01-E320 & 02-ST2
Quoted: 35 Post(s)
Hi, Marv.
Since you posted into the "general" forum, didn't complete your BW profile for location and vehicle, and didn't otherwise identify your car in any way, I can only suggest that you use whatever tool is neede for that purpose on your car.
If you click the user cp link you can complete the profile, and if you look down the forum to the section that is specific to whatever car you own, then you can search that forum or post in there and the people most familiar with your model may be able to answer your question.
Take care and enjoy the ride,
Greg
Check Codes is offline
post #3 of 11 (permalink) Old 05-02-2009, 06:14 PM
Kajtek1's Avatar
Quoted: 1289 Post(s)
could also be a Torx
Welcome to the forum
Kajtek1 is offline
post #4 of 11 (permalink) Old 05-02-2009, 06:17 PM Thread Starter
MiamiMarv's Avatar
screw or allen wrench
Sorry i'll do that after this post. The problem is I don't know what tool to use...thats why i asked the question....It is a 1994 benz E320....there is a coin rattling around under the horn cover and there are two holes in back of the steering wheel which i know contains screws to remove this cover...I just need to know what kind of screws they are.
post #5 of 11 (permalink) Old 05-02-2009, 06:46 PM
Quoted: 35 Post(s)
If it's like the 210 they are indeed torx, T30 IIRC. But the geniuses in the W124 forum will know for sure, so check them out.
Greg
post #6 of 11 (permalink) Old 05-02-2009, 06:46 PM
Kajtek1's Avatar
The truth is that even the same MY come with different fasteners. Most likely it is Philips screw, but if you have one of those miniature cameras -taking a picture would be a good start.
The old fashion mirror suppose to work as well.
Kajtek1 is offline
post #7 of 11 (permalink) Old 05-02-2009, 08:44 PM
Date registered: Dec 2008
Vehicle: w204 (C350ELE)
Post
When you look it up, if it is a cross is a Phillips, if it is a multipoint star is a Torx, if it is a hex is Allen (but the Torx should work). And Kajtek says if is Torx is a T30 IIRC.
Cheers, JV
JoeVal is offline
post #8 of 11 (permalink) Old 05-03-2009, 03:30 AM Thread Starter
MiamiMarv's Avatar
I love this forum already...thx for your help.
post #9 of 11 (permalink) Old 05-03-2009, 05:50 AM
keyhole's Avatar
Date registered: Sep 2006
Vehicle: 2004 CLK 240 Coupe
Quoted: 404 Post(s)
Marv - what you describe as the 'horn cover' is most likely the airbag. The WIS advises great care in handling this unit, and provides the correct sequence for its safe removal.
Post your question in the right forum, with all the necessary details of your model, and we can give you further advice with WIS data, eg torque values for re-assembly.
keyhole is offline
post #10 of 11 (permalink) Old 05-03-2009, 07:27 AM
Date registered: Apr 2009
Vehicle: Current: 1987 560 SEC US, former factory trained MB tech 10 years, owner of 14 others.
First, use a mirror and a small flashlight to see what you have.
renaissance_warrior is offline
Rear Differential: What size Allen wrench? SteveMras R170 SLK-Class 8 04-11-2009 11:24 AM
Even Paul Allen knows what's best FLX Off-Topic 17 02-07-2006 05:16 AM
Help! How do u remove a 99 exhaust tip? D Allen wrench nut is stuck. Can it be loosen? DLeconte R170 SLK-Class 4 03-06-2002 07:15 AM
Q. What size allen wrench to replace front brake pads? darren R170 SLK-Class 6 09-09-2001 03:01 PM
Metric Allen Wrench for Manual Transmission and Differential Oil Check Guest (MBNZ) W123 E,CE,D,CD,TD,TE Class 1 09-04-2001 07:48 AM
