Seeking experienced advice - coolant leak between engine & trany - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 04-30-2009, 04:19 AM Thread Starter
Date registered: Apr 2009
Vehicle: S600L, 500CL, 560SL
Send a message via Skype™ to shopcarpro
Question Seeking experienced advice - coolant leak between engine & trany
Hi everybody, Newbie need knowledgeble / experienced contribution at this juncture from forum members. Coolant pouring out of the lower joining plane between the motor and trany in my 93 500 Coupe' as seen here. Just started this leak. Resovior level goes down to almost to the bottom line due to this leak and the leak stops. All visible hose connections show no leak. Also no wetness in the back of 119 engine to the touch. Had the throttle linkage assy. removed to access. Checked out all past posts with coolant leak as key words. Has anybody gone thru the same experience?????????? Or what would be the keywords to search for any past posts. Thanx in advance for any valuble info.
shopcarpro is offline
post #2 of 2 (permalink) Old 08-10-2009, 10:57 AM
leapyfish's Avatar
Date registered: Apr 2008
Vehicle: 1998 SLK230 199,xxx Miles
Quoted: 4 Post(s)
leapyfish is online now
    Coolant Leak, Need Advice mslchief W140 S-Class 5 04-21-2009 12:59 PM
    adam a190 from hong kong shimato W168 A-Class 4 05-23-2007 10:20 PM
    Seeking experienced advice on awnings Hipine G-Class 2 07-08-2005 08:39 AM
    Amp ripped out - need experienced advice bs00clk C208/A208 CLK-Class 0 12-02-2004 03:14 PM
    Seeking advice on water leak hudsmore R129 SL-Class 1 01-18-2004 08:15 PM
