Brake light fault - Mercedes-Benz Forum
post #1 of 12 (permalink) Old 04-29-2009, 01:28 PM Thread Starter
smudgenav's Avatar
Date registered: Apr 2009
Brake light fault
Hi all this is a fault that i hope someone has had some dealing with as i cant really afford to go to the dealers the fault is displayed on the dash when the brake pedal is pressed.
I bought a code reader and this is what the codes said
4404 The CAN signal from component S9/1 (Stop lamp switch) of the traction system is implausible
4600 The voltage supply of circuit 87 has undervoltage
4602 the voltage supply of the valves is faulty.
I changed the brake switch it had no effect!!
Pls Help
Andy
smudgenav is offline
post #2 of 12 (permalink) Old 04-29-2009, 03:29 PM
Musikmann's Avatar
Quoted: 6 Post(s)
I don't understand your last sentence. Did you mean you changed the brake light switch and that didn't solve the problem?
To state the obvious, did you check to see if both brake lights work? If not, check the bulb(s) and the socket(s) they plug into.
Musikmann is offline
post #3 of 12 (permalink) Old 04-29-2009, 03:34 PM Thread Starter
smudgenav's Avatar
Yes mate i changed the switch and checked all the bulbs there is no power getting to the right hand brake light.
post #4 of 12 (permalink) Old 04-29-2009, 03:45 PM
Musikmann's Avatar
Quoted: 6 Post(s)
Mate?...you sound like an Aussie! Now we're getting somewhere, no power. How about a bad fuse and do the wires look O.K? BTW it would be helpful for someone if you tell us what type of MB you have (year and model).
post #5 of 12 (permalink) Old 04-29-2009, 03:53 PM Thread Starter
smudgenav's Avatar
Well as far as i can tell the wires look fine and all the fuses are too i have a C32 AMG (2002) all the other lights in that cluster work so im guessing its something upstream ?? and no im not an Aussie
post #6 of 12 (permalink) Old 04-29-2009, 04:02 PM
Musikmann's Avatar
Quoted: 6 Post(s)
In my car series (W210) the brake light sockets are often to blame for a brake lamp failure indicator so that's why I suggested that. If those are O.K. as well as the bulbs, wires and fuses, then it's indeed time to look upstream. That's where I'd be lost though; hopefully someone else will chime in. If all else fails, look for the model-specific forum for your car and ask the other C32 owners.
post #7 of 12 (permalink) Old 04-29-2009, 04:07 PM Thread Starter
smudgenav's Avatar
Cool il post this subject on the C32 owners forum and see if that can rattle a few answers.
Thanks for the chat bud.
post #8 of 12 (permalink) Old 04-29-2009, 04:14 PM
Musikmann's Avatar
Quoted: 6 Post(s)
My pleasure, and best of luck!
post #9 of 12 (permalink) Old 04-29-2009, 04:34 PM
daddi's Avatar
Vehicle: E420 '94 240D '82 200E '91
Pls Help
Andy
The rear SAM may be faulty, check for condensation in the boot.
E420 '93
240D '82 "The wheel"
200E '91
230E '83 "archaeological effect"
Contra verbosus noli contendere verbis, sermo datur cunctis, animi sapientia paucis.
Mercedes technician 20 years fixing Mercedes.
daddi is offline
post #10 of 12 (permalink) Old 04-29-2009, 05:10 PM
Musikmann's Avatar
Quoted: 6 Post(s)
What is the SAM please? Condensation is the probable cause of the faulty bulb sockets too, if I'm not mistaken.
    Brake Pad light & brake light - not the usual Stitch W163 M-Class 11 11-21-2008 09:28 AM
    Fault light benzhead R170 SLK-Class 3 03-08-2007 04:58 PM
    Brake fault code C1330 Chris1501 W203 C-Class 0 11-12-2006 09:15 AM
    Brake Pad Light & Parking Brake light come on when Complete Stop Yianni General Mercedes-Benz 1 04-02-2006 08:42 AM
    Brake Pad Light & Emergency Brake Light Come on when I come to stop Yianni General Mercedes-Benz 3 03-29-2006 09:57 AM
