82 300TD 2 injector heat shields found installed in #1? - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 04-21-2009, 01:17 PM Thread Starter
Goldenvoice's Avatar
Date registered: Jun 2006
Vehicle: 82 300TD Turbo Diesel Wagon
Changing out #1 injector with a spare used one today: when I used my wire hook to pull the old heat shield out from the hole, I pulled up two - count them, 2 different heat shields. Is the bottom one supposed to be/stay in there? What's going on here??? (I've only removed #1 - it was missing @ idle...)
Goldenvoice is offline
post #2 of 2 (permalink) Old 04-21-2009, 04:35 PM
Administratoris Emeritus
GeeS's Avatar
Vehicle: 2021 SL770
Quoted: 695 Post(s)
Keep the one on the left, toss the other...
GeeS is offline
    300TD fuel injector removal mriplaybass W123 E,CE,D,CD,TD,TE Class 9 03-28-2009 03:18 PM
    diesel injector heat shields p100 W126 S,SE,SEC,SEL,SD,SDL Class 3 10-29-2007 07:48 AM
    77 240 heat shields black cloud W123 E,CE,D,CD,TD,TE Class 0 04-18-2007 08:44 AM
    Exhaust Heat Shields mramay W126 S,SE,SEC,SEL,SD,SDL Class 2 07-05-2006 11:07 AM
    injector heat shield size? luxurious W123 E,CE,D,CD,TD,TE Class 1 02-02-2005 04:26 PM
