Brake Warning Lamp - Mercedes-Benz Forum
post #1 of 10 (permalink) Old 04-09-2009, 07:41 PM Thread Starter
Date registered: Apr 2008
Brake Warning Lamp
My '87 560SL has been in storage since December. I only drove it around the parking lot about once a month during the winter, but the snow finally melted in Chicago, and it was time to hit the road!
The brake warning lamp went on immediatly, and has been "acting-up". It would go on and off with different light intensity, but not directly related to whether I am braking.
Then it went off completely, but would return with more or less intensity with
lower or higher rpm's, never touching the brake pedal.
The fluid level is OK, about one half inch below maximum, and there doesn't appear to be any problem with the brakes.
Seems strange to me. Anyone had a similar experience?
jrtravel is offline
post #2 of 10 (permalink) Old 04-09-2009, 10:01 PM
stox's Avatar
Date registered: Dec 2004
Vehicle: 1996 C36, 1995 S500 Coupe, 1985 190E 2.3
Send a message via Yahoo to stox
I had a similar problem on my S500C. The cause was corrosion in the connector to the sensor on the brake fluid reservoir. Cleaned it up, and no problem since.
stox is offline
post #3 of 10 (permalink) Old 04-10-2009, 02:20 PM
Date registered: Jan 2004
Quoted: 30 Post(s)
Which warning light, the yellow one or the red one?
Len
sokoloff is offline
post #4 of 10 (permalink) Old 04-10-2009, 02:27 PM
~BANNED~
Date registered: Sep 2007
Vehicle: 99 Merc S420 (80k Mi) 07 Lexus LS460 (21k Miles)
Are you talking about the low brake fluid light or the exterior burned out bulb light?
mr.xpowerseller is offline
post #5 of 10 (permalink) Old 04-10-2009, 09:43 PM Thread Starter
There are two brake lights, the red brake warning lamp(owners manual #23), the yellow brake pad wear indicator lamp(owner manual #22). There is also the yellow exterior light failure indicator lamp(owners manual #17). My problem is the red brake warning lamp.
I will take a look at the sensor connector.
jrtravel is offline
post #6 of 10 (permalink) Old 04-11-2009, 05:07 AM
Quoted: 30 Post(s)
The red brake warning light tells you two things:
1. Parking brake is engaged or
2. Brake fluid is low.
There are two chambers to your brake fluid reservoir. You can often times be fooled into thinking that the reservoir is full when in fact the rear chamber might be low. You might have to jiggle it or shine a light on the reservoir to verify that you have the correct fluid level. Also one of the two sensors could be bad or sticking.
Len
sokoloff is offline
post #7 of 10 (permalink) Old 04-11-2009, 07:58 PM Thread Starter
I filled the reservoir to maximum, and cleaned the sensors. I am not sure which worked, but the light is out!
Thanks for your help guys!
...and Stox, No fighting in here! This is the chat room!
jrtravel is offline
post #8 of 10 (permalink) Old 04-12-2009, 12:04 AM
stox's Avatar
I have no idea what you are talking about.
stox is offline
post #9 of 10 (permalink) Old 04-12-2009, 06:37 AM Thread Starter
I thought that might be a litt too obscure Dr. Strangelove reference(your picture). I am a bit of a movie fan, and movie quote fan, and the president, Peter Sellers says to the group assembled, "Gentlemen, you can't fight in here! This is the war room!"
jrtravel is offline
post #10 of 10 (permalink) Old 04-12-2009, 09:26 AM
stox's Avatar
Ah, I get it. I m going to gather my 10 women now.
stox is offline
    W211 Brake Warning, ESP Warning Lights? willy_manilly W211 E-Class 0 02-16-2009 10:27 PM
    defective lamp warning solarant W210 E-Class 9 11-19-2007 12:13 PM
    Lamp Defective light (brake lamp) BatBenz W210 E-Class 8 08-18-2005 03:23 PM
    Lamp Out Warning alex lynch W163 M-Class 1 01-31-2003 01:54 PM
    '99 R170: spurious brake lamp warning light Dick W R170 SLK-Class 3 11-21-2002 02:03 PM
