W211 E270 CDI, 2004 Heater problem Solved - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 03-27-2009, 10:49 AM Thread Starter
Date registered: Feb 2005
Send a message via Yahoo to piksend
Cool W211 E270 CDI, 2004 Heater problem Solved
Hi folks, heater on my W211 kept blowing cold air even when settings were at max heat. Sometimes fault would cure it'self till it failed permanently.
THis is how I solved the problem: Found a 4-way motorised valve right under the brake-servo/master cylinder assembly had ceased, due to corrosion on motor:-looked like coolant fluid found it's way into the motor's chamber. This is quite a difficult part to access and change, so allow up to 4 hours to do the job. Had to do the following:
1. Disconnect battery- A MUST
2. Disconnect all control modules and fuse panel on the left hand side of the engine compartment. Remember to mark connector positions
3. Remove the housing for the 3 control modules, taking care not to snap any cables.
4. You can now view the 4-way valve right under the brake-servo assembly.
5. Cover all the cable connectors with a lage towel.
5. Push back 3 metal clips on the valve to release 3 of the pipes. (a little coolant fuid will leak, hence the need to cover the cable connectors)
6. 4th pipe will require use of pliers to release the horse clip.
7. Fit new motorised valve & the rest in reverse order, making sure all connectors have fitted tightly. Battery connection is the LAST step.
8. Top up lost coolant
9. Test run & you should be smiling, well at least I was, and I saved £450!
piksend is offline
post #2 of 2 (permalink) Old 03-27-2009, 12:02 PM
Diesel Benz's Avatar
Quoted: 32 Post(s)
Diesel Benz is online now
    Need Help: E270 CDI Turbo Problem gka W211 E-Class 19 04-30-2015 05:55 AM
    No Heater/Aircond/Blower -Nothing-Problem solved- Merc-S600 W140 S-Class 0 12-15-2008 10:01 PM
    Exhaust system problem solved, now onto Heater motor noise! will3hawks2 W124 E,CE,D,TD Class 0 02-27-2005 05:38 AM
    E270 Cdi - engine management problem delays delivery marc777 W211 E-Class 4 10-23-2002 01:36 PM
