98 ML 320 Bad ECU, would a used one work? - Mercedes-Benz Forum
post #1 of 1 (permalink) Old 03-24-2009, 05:09 PM Thread Starter
Date registered: Mar 2009
Vehicle: 1998 ML 320
Unhappy 98 ML 320 Bad ECU, would a used one work?
Hi everyone, I am new to this, and have a very bad problem. My dad purchased an ML 320 to sell it in Mexico. One day before taking it to Mexico City, the ECU seemed to have gone wrong. At least I think it's that, because I have read some forums with the same problems and that seems to be the problem. What happens is this:
First, the car wouldnt star what so ever, you would turn the key and no sounds would be made, anything. A mechanic came to the house, checked it, when he plugged his scanner, it started. It has started since all the time, but now the trans is not shifting gears. On the scanner, the message "no communication between engine and transmission" appears. Thats what the mechanic told me. When you drive the car, the speedometer does not work, it drives but only fist gear and reverse. The check engine light came on. I really don't know what it could be. At the dealership they say they need to change the speed sensors on the wheels, change the ecu, change some other modules, etc. I am really hoping someone here has the expertise to help me. I bouth a used ECU, and at the dealership they say I need to buy a new one, since the codes won't work for this car. I just leave it open for anyone to help, appreciate it guys.
Mikealvarez is offline
    Symptoms/Problems due to bad ECU/ECM? chrisdpham W124 E,CE,D,TD Class 4 09-18-2011 02:06 PM
    Fan always at full, bad ECU???? motoadve W203 C-Class 1 02-05-2008 01:17 AM
    5th gear and ECU work together sjdavis83 W140 S-Class 2 10-09-2007 11:51 PM
    Performance ECU Chip - Good or Bad ? GODZILLA W140 S-Class 3 06-10-2005 01:02 PM
    Will an slk 320 eisenmann exhuast work on my clk 320? Same year too. bib C208/A208 CLK-Class 0 12-13-2001 07:51 AM
