My Car is in Limp Mode...HELP!!!!!! - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 03-22-2009, 09:07 PM Thread Starter
Date registered: Mar 2009
2000 Mercedes Benz C230 Kompressor Sport
So, we have the good ol' code for the Input/Turbine Speed Sensor Malfunction (P0715). Just replaced the conductor plate on top of the valve body, put everything back together, new fluid, filter, and cleared the codes, only to be welcomed with it still throwing the same code while keeping the car in limp mode. Tiptronic is stuck in 'D' and will not shift while also requiring extra revs to move along. Also idles hard while in gear, though smooth at idle. Already replaced the MAF and am not seeing any codes for it.
So someone please advise! The only other thing I can think of is the TCU and I would rather not have to get involved with replacing a $1000 part as far as my knowledge goes.
Inferno is offline
post #2 of 3 (permalink) Old 03-22-2009, 10:16 PM
Check Codes's Avatar
Vehicle: '01-E320 & 02-ST2
Quoted: 35 Post(s)
Welcome to the forum. You might find more info from the forum native to your car, but the trans is in lots of cars so search for your code.
Couple of thoughts, though. Did you also change the adapter/connector outside the trans? How wet was the plug? Did you open the TCU box to see if it is wet? Last, how did you clear the codes? Regular OBD or battery disconnect won't do it, takes the proper interface to the diag port as these are hard codes. And just fixing the problem won't clear the code, either.
Take care and enjoy the ride,
Check Codes is offline
post #3 of 3 (permalink) Old 03-23-2009, 08:50 AM Thread Starter
Thanks. I am going to take it into the shop and get it diagnosed. I really hope its not a TCU problem.
Inferno is offline
    ABS- ESP- Engine light- limp mode after car wash tbrown W211 E-Class 8 11-07-2013 09:36 AM
    ASR Light comes on and car goes into Limp Mode masaki@japan R129 SL-Class 51 05-02-2009 01:34 PM
    Limp Mode noelchambers R170 SLK-Class 4 08-18-2008 01:27 PM
    LIMP MODE V-TECH W203 C-Class 0 06-27-2008 12:43 PM
    The Reason My Car Went To "Limp Home Mode" driver450190 W203 C-Class 0 01-22-2008 08:19 PM
