C230Kompressor won't start - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 03-21-2009, 03:30 PM Thread Starter
Date registered: Jan 2009
Unhappy C230Kompressor won't start
I have a 1999 C230 Kompressor that sat for a couple of years and now i cannot get it started. I've installed a new starter, as well as a new (and proper for this car) battery. With the new battery I can get it to maybe crank almost a complete rotation, then I jusr get a slight movement each time I try the key. With batterys from my other cars (which weren't as big as the one its supposed to have best I ever got was a very slight movement of the crankshaft (by watching the fan as I crank it) Now I get much more ritation, but still nothing significant. Waiting or charging the battery gets me a bit more again, but never do I get cranking with any speed where you would think it might start. Before the car sat, it was running great. I really would appreciate any suggestions on what i could check next. the key is synched and locks and unlocks the doors, everything else seems to work, just can't get it running.
jceh1 is offline
post #2 of 3 (permalink) Old 03-23-2009, 06:33 AM
bmeister's Avatar
Date registered: Oct 2007
Vehicle: 1998 c230 162K
Quoted: 9 Post(s)
I would change the oil and filter and probably empty the gas tank, thats quite a while to be sitting with old gas. New spark plugs may be in order as well. Make sure your battery has not discharged with all the failed cranks. B
bmeister is offline
post #3 of 3 (permalink) Old 03-23-2009, 12:38 PM
gottabemb's Avatar
Vehicle: 1990 300CE w/AMG parts; 1995 Range Rover; 2005 Ford F-150 Lariat
I found this when I was curious about my own C230:
"Believe it or not, jump starting a modern vehicle with several computers can cause a lot of problems. it can corrupt the software in 1 or more of the major computers. I know this because I was a lead diagnostic tech at major German and European Dealerships and Independent Shops. If you don't feel confident about the work being performed at the dealership, go to a MB owners forum online and find out ask who the best MB shop is in your area and who specializes in sophisticated electrical and computer trouble shooting. Excellent independent shops have the where with all to reprogram the computers with the HHT ( the MB diagnostic and reprogramming capable laptop ) Typically if a car has been jump started several times, ( many tow truck drivers are very behind the times in this area ) the computers need to be reprogrammed which can take many hours but should not require too many parts other than an over load relay or 2."
Hope you get it all worked out.
gottabemb is offline
    Looking for Powerplant W202 C230Kompressor alexor13 For Sale/Wanted/Trade/Giveaway 0 06-27-2007 09:26 AM
    Search failed: Converting c230 to c230Kompressor BMWkompressor W202 C-Class 2 02-06-2007 11:17 AM
    2005 C230Kompressor Supercharger pulley for sale spookie For Sale/Wanted/Trade/Giveaway 2 10-18-2006 10:45 PM
    Anybody knows about aftermarket pulley kit for a 2005 C230Kompressor SS? spookie W203 C-Class 2 08-26-2006 12:16 PM
    C230Kompressor sedan 2004 update dt89 W203 C-Class 7 11-25-2003 05:20 PM
