E280 Estate W124 1994 Gearbox Issue - Mercedes-Benz Forum
post #1 of 5 (permalink) Old 03-21-2009, 05:55 AM Thread Starter
Bhups's Avatar
Date registered: Apr 2007
Hi everyone,
Im kinda new to the forum and need some help from you guys.
I have 94 E280 W124 Estate - recently I've issues with the gearbox such that it would never kickdown properly, and then as I'm coming to a stop, the gearbox shunts into a lower gear.
I've had the gearbox ECU replaced and checked the oil, it is somewhat better, but does not kickdown correctly when approaching a roundabout say, I pull away but there is no power until I really press the accelerator hard.
Any help would be greatly received.
Thanks
Bhups is offline
post #2 of 5 (permalink) Old 03-21-2009, 03:01 PM
flyboyike's Avatar
Date registered: May 2003
Vehicle: 2012 Focus SE
Quoted: 68 Post(s)
Kickdown cable checked?
flyboyike is offline
post #3 of 5 (permalink) Old 03-21-2009, 03:19 PM
Administratoris Emeritus
GeeS's Avatar
Vehicle: 2021 SL770
Quoted: 664 Post(s)
Could be a modulator valve problem/adjustment. That's where I'd start.
GeeS is offline
post #4 of 5 (permalink) Old 03-22-2009, 05:07 AM Thread Starter
Bhups's Avatar
Thanks for the responses
I've checked the kickdown cable and made slight adjustments, but this did not work.
Where is the modulator valve?
Regards
Bhups is offline
post #5 of 5 (permalink) Old 03-22-2009, 06:23 AM
flyboyike's Avatar
Quoted: 68 Post(s)
On the side of the transmission.
    Would these R171 rims fit my E280 estate? tobyd W124 E,CE,D,TD Class 0 08-27-2008 01:09 PM
    Cat needed for w124 E280 estate tobyd W124 E,CE,D,TD Class 0 08-25-2007 10:59 AM
    Mercedes E280 Estate mercedesmickey W124 E,CE,D,TD Class 0 08-24-2006 02:06 AM
    1996 E280 estate sportline mercS600 W124 E,CE,D,TD Class 3 04-29-2006 09:12 AM
    E280 W124 1994 ¨repalcing the Telescopic antenna Guest (MBNZ) W124 E,CE,D,TD Class 3 02-19-2002 02:57 PM
