1989 300E charging problem - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 03-15-2009, 10:17 AM Thread Starter
Date registered: Mar 2009
I have 89 300E with a charging problem. If I let sit overnight battery is drained and will not turn over. I thought it was battery so I replaced it with new. It will start and run for several times during the day, but when I let it sit for several hours overnight battery dead. I can't hear any motors running or notice any lights on causing the drain. Any ideas.
tngunsmith is offline
post #2 of 4 (permalink) Old 03-15-2009, 11:21 AM
Administratoris Emeritus
GeeS's Avatar
Vehicle: 2021 SL770
Quoted: 544 Post(s)
There is an open short somewhere, it could be a failed electronic item.
GeeS is offline
post #3 of 4 (permalink) Old 03-15-2009, 12:09 PM Thread Starter
How would a person go about finding an open short? Any ideas would be appreciated. Thanks.
post #4 of 4 (permalink) Old 03-15-2009, 03:26 PM
Andrzejek's Avatar
Date registered: Jul 2004
Vehicle: 00 C-230, 04 C-240
Not sure if your car has the same electric seat cirucits as some of the C-class vehicles have, but the seat electrics have been a problem in the past with numerous posts. It should be very easy to either, disconnect the circuits or pull the fuses, to check if this is the problem.
If the seats are not the problem, than I would recommend placing a voltmeter directly across the battery terminals & observing the votage as each circuit fues is pulled. One thing to keep in mind is that some units might have to be reset once voltage is disconnected (radio code reset, for example).
Good luck.
Andrzejek is offline
    87' 300E 3 litre. CHARGING OR BATTERY PROBLEM?!? 300eguy77 W124 E,CE,D,TD Class 21 12-01-2009 10:28 AM
    1989 300E Power Seat Problem. Madbury General Mercedes-Benz 1 02-12-2009 02:04 PM
    Mercedes 300e 1989 Rev Limiter Problem! richy.a W124 E,CE,D,TD Class 8 06-14-2008 05:24 AM
    1989 300E stalling problem gana W124 E,CE,D,TD Class 2 04-07-2006 12:09 AM
    1989 300E Cruise Control problem rmpjr7 W124 E,CE,D,TD Class 1 01-06-2006 11:02 PM
