Rough idle 500 sel 1984 - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 03-13-2009, 09:04 PM Thread Starter
Date registered: Mar 2009
Replaced fuel filter check for vacuum leaks idle control and valve good. Does anyone know if there are fuel strainers in fuel distributor?
johnlawrence6@msn.com is offline
post #2 of 3 (permalink) Old 03-13-2009, 09:10 PM
Administratoris Emeritus
GeeS's Avatar
Vehicle: 2021 SL770
Quoted: 695 Post(s)
Not exactly sure what that means, but I wouldn't be opening up your fuel distributor if I were you. If the diaphragm is bad, you won't find a replacement part anyways...
GeeS is offline
post #3 of 3 (permalink) Old 04-14-2009, 12:14 PM
Date registered: Apr 2009
Vehicle: 1987 560SEL, 1988 300E, 1989 300SE
Once you have determined that there are no vacuum leaks, plugs and wires, rotor and cap are good, and the vacuum control valve are ok, the culprit is usually the idle control unit. It is found under the carpeted toe board on the passenger side of the car. It gets really technical to test them, and my suggestion would be to just buy another one. You can get them pretty cheap at any parts yard.
jddrewer is offline
    84 500 sel rough and high idle johnlawrence6@msn.com W126 S,SE,SEC,SEL,SD,SDL Class 0 03-04-2009 12:30 PM
    rough idle , no heat when idle 02 g 500 jakub.baraniak G-Class 3 02-02-2009 09:36 PM
    1984 500 Sel noctum W126 S,SE,SEC,SEL,SD,SDL Class 4 10-27-2006 04:58 PM
    1984 500 Sel Timmy Crass W126 S,SE,SEC,SEL,SD,SDL Class 5 09-17-2006 04:01 PM
    1984 500 sel toyota lover General Mercedes-Benz 0 11-06-2004 09:59 PM
