cant unlock or start my clk 230 - Mercedes-Benz Forum
post #1 of 9 (permalink) Old 03-12-2009, 07:51 AM Thread Starter
Date registered: Mar 2009
Angry cant unlock or start my clk 230
any one had the same problem or know any answers please?
went to unlock with my key fob but didnt work so changed batterys, still didnt work.
unlocked the drivers door with the slide out key but then i couldnt even start the car, nothing happening at all, cant get it out of park gear or get steering lock of.
nikkijane is offline
post #2 of 9 (permalink) Old 03-12-2009, 08:06 AM
Diesel Benz's Avatar
Quoted: 35 Post(s)
And what happened with your spare key?
Diesel Benz is offline
post #3 of 9 (permalink) Old 03-12-2009, 08:10 AM Thread Starter
i havnt got a spare key, just the key fob with infar red with a key that slides out of the side of the fob
post #4 of 9 (permalink) Old 03-12-2009, 08:51 AM
Jetjok's Avatar
Date registered: Jan 2009
Vehicle: 2002 CLK320; 2006 CLK350 Cabriolet; 2011 E350 Cab; 2014 E550 Cab
Silly question, but is the battery charged? The car battery that is.
Jetjok is offline
post #5 of 9 (permalink) Old 03-12-2009, 09:03 AM Thread Starter
lol yes the battery is charged and we even tryed starting it with a jump pack on the battery but still nothing at all.
post #6 of 9 (permalink) Old 03-12-2009, 10:21 AM
Quoted: 35 Post(s)
I was afraid of this. I'm reluctant trying to help owners that do not care to keep two active keys for the car but you probably have a good reason for this.
I assume the key does not turn in the ignition slot? Then it sounds like an EIS or key issue. You could check if the key emits an IR signal (take a photo with a digital camera when you press a key).
In the ignition slot the key does not need batteries but when you test it, batteries need to be correctly placed.
If you do get an IR signal, I'd open the key, take the circuit board out and check that the power coil is in place, switches and other solder points are fine.
But if the car has power but doors do not open with the remote, it sounds like a more serious issue with the key. At this point either the RF or the IR part would be sufficient, so I cannot figure out a common problem.
If the key turns in the ignition slot, then it is something different, in this case the car has authenticated the key.
post #7 of 9 (permalink) Old 03-12-2009, 12:57 PM Thread Starter
any 1 know wheres the best place to get a new key from and when i get it will it work straight away or will it need programing to the car? any 1 also know the price of key roughly
post #8 of 9 (permalink) Old 03-12-2009, 07:45 PM Thread Starter
i used a digital camera to see if my ir was working on my key and it is so does that mean my key is o.k and its some thing wrong with the car then????
post #9 of 9 (permalink) Old 03-14-2009, 02:54 PM Thread Starter
thanks everyone for your help...... i ordered a new key yesterday and picked it up today and it works....so it must of been my key.... cheers x
    remote wont unlock 01 clk 320 lodownlv General Mercedes-Benz 10 10-11-2009 01:07 PM
    '01 Clk 320 radio unlock procedure -have code Babalu95 Audio & Telematics Forum 4 03-10-2009 11:59 PM
    CLK 240 tv unlock code reqd mikeym98 C209/A209 CLK-Class 1 03-23-2008 02:37 PM
    66 230 SL Smokes on start up Guest (MBNZ) Vintage Mercedes-Benz 6 12-08-2003 06:56 PM
    Remote Start/Unlock lrottering Audio & Telematics Forum 8 10-06-2003 09:31 AM
