Can a fuel pump have a fuse and a relay? - Mercedes-Benz Forum
post #1 of 1 (permalink) Old 03-09-2009, 02:43 PM Thread Starter
Date registered: Mar 2009
I put a new fuel filter on and went to tighten the fuel pump screw with the engine still running. When my wrench touched the fuel pump there was a spark and the engine cut off immediately. Did I burn out the fuel pump relay or fuse? But if I have a relay do I even have a fuse?
teacher man is offline
    1988 260e w124 no fuel...changed fuel pump and relay!! salthepal W124 E,CE,D,TD Class 11 01-07-2012 08:32 AM
    Fuel Pumps or Fuel Pump Relay MKUltra R/C107 SL/SLC Class 21 05-31-2009 08:32 AM
    Fuel Pump Relay cruicky68 R/C107 SL/SLC Class 7 02-02-2007 09:58 AM
    1986, 420sel no power to the starter of fuel pump,is it a relay or a fuse forgetaboutit1970 W126 S,SE,SEC,SEL,SD,SDL Class 3 04-02-2006 10:06 AM
    380sel where is the fuel pump fuse? have no power to pump meggala W126 S,SE,SEC,SEL,SD,SDL Class 3 08-02-2005 03:44 AM
