Windshield Washer Warning Light---How Do I Disconnect It - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 03-06-2009, 06:41 AM Thread Starter
Date registered: Mar 2009
Vehicle: 1992 MB 300D 2.5Turbo
I've got a W124 (92 300 TD). The windshield washer warning light is on (and I know why---the tank leaks, but I'm too cheap, for the time being, to replace it).
Can someone tell me (or direct me to another thread) how to disconnect the warning light?
Martskers is offline
post #2 of 4 (permalink) Old 03-06-2009, 10:28 AM
PLeeson's Avatar
Date registered: Apr 2007
Vehicle: 2012 S550 4Matic
Quoted: 5 Post(s)
Unplug the connector from the tank and short the plug, making the system think the circuit is closed, as would be the case were the tank full.
This presumes the sending unit works!
But, for $50 at AutoHaus, why not just replace the tank?
Part # 1248690720
Prior MBs:
1971 250, 1983 380SEL
1986 190E2.3, 1987 300TD
1994, 2003, 2005 SL500s
2001 E320 4Matic
2011, 2012 E350 4Matics
PLeeson is offline
post #3 of 4 (permalink) Old 03-06-2009, 10:50 AM
Diesel Benz's Avatar
Quoted: 32 Post(s)
Shorting the plug may not work, some cars have sensors in series and usually at least there is a fixed resistance when a switch is closed, for diagnosis purposes (allowing short circuit and open circuit being detected).
Either a correct resistor or shorting the circuit "behind the resistor" would work for sure.
Diesel Benz is offline
post #4 of 4 (permalink) Old 03-06-2009, 10:56 AM
Check Codes's Avatar
Vehicle: '01-E320 & 02-ST2
Quoted: 35 Post(s)
Have you checked to see why it is leaking? Mine was and it was a rubber seal on the pump where it goes into the tank, I think it was about 25 cents and three minutes' work.
If you plan on staying, please click the User CP link and complete your BW profile to include vehicle and location as that is often useful information.
Take care and enjoy the ride,
Check Codes is offline
    Disconnect warning buzzer?? SheepAlert W126 S,SE,SEC,SEL,SD,SDL Class 11 05-26-2011 02:06 AM
    No low windshield water warning light.. bestjsg W245 B-Class 9 12-19-2007 07:44 PM
    Windshield Washer baker462 Vintage Mercedes-Benz 1 02-07-2007 06:49 AM
    Windshield washer "refill" light illuminated constantly Rollingstone W126 S,SE,SEC,SEL,SD,SDL Class 9 10-17-2005 02:16 PM
    Park Brake warning Light and Low fuel warning light Ameet Patel R170 SLK-Class 3 03-21-2001 03:28 PM
