Mercedes-Benz Diagnostic Trouble Codes (DTC) for 1996+ models - Page 4 - Mercedes-Benz Forum
post #31 of 38 (permalink) Old 12-16-2014, 10:07 AM
Date registered: Dec 2014
2005 Mercedes c230 kompressor
Transmission code- p240c. ?
mechwarriortech is offline
post #32 of 38 (permalink) Old 02-26-2015, 02:23 PM
hilarushi's Avatar
Date registered: Jan 2007
Vehicle: W210, W211, W163
Quoted: 5 Post(s)
hilarushi is offline
post #33 of 38 (permalink) Old 06-09-2015, 02:27 AM
Date registered: Jun 2015
Vehicle: 2002 e 270 w11
liste codes defaut p0100 en cliquant dessus on voyait la photos de la pièces as change . il y as plus de photos: demande renseignements merci
js92500 is offline
post #34 of 38 (permalink) Old 07-29-2015, 10:07 PM
Date registered: Jul 2015
Vehicle: 1999 C280 Sport
dtc codes
I took my 1999 C280 sport in for a change of spark plugs and spark plug wires, at a local shop, when the tech was finish, he said 4 dtc codes came up, p0400, p017, p0173 and p0105. These codes were not there when the car went in, what would change this now, and am i getting hustled by the shop. They told me it would cost about $500 to fix all issues or is there something i can do to correct then code myself.
Rj James is offline
post #35 of 38 (permalink) Old 06-06-2016, 05:35 AM
LillianJacks's Avatar
Date registered: Jun 2016
Vehicle: MERCEDES BENZ C-Klasse Coupe AMG 2011
Mercedes Ml 320 cylinder 6 misfire I'am getting a message "Cylinder 6 misfire detected" after checking the couse of "Check engine" light comming on. I cen reset the check engine light but when I suddenly accelerate it will come back and will not go off after restarting the car.
LillianJacks is offline
post #36 of 38 (permalink) Old 04-25-2017, 07:21 AM
Date registered: Sep 2013
Vehicle: 1999 ML320, 2003 SLK32
Quoted: 25 Post(s)
OK, here's a mystery for you
P3501 on a 2003 SLK32 AMG... coupled with no power, intermittant BAS/ESP light.
https://goo.gl/photos/EArtxep7KACJvE7W6
I know about the air injection stuff, that shouldn't cause limp mode?
Sinbadd is offline
post #37 of 38 (permalink) Old 05-25-2017, 09:54 PM
Date registered: Aug 2015
Vehicle: 2000 ML 320
Do the codes reset themselves when the problem is fixed, or do they need to be reset manually? And how long or how many drive cycles are required before one can say "that was the problem, because the codes are not coming back"? thank you.
Tom Delaware is offline
post #38 of 38 (permalink) Old 05-25-2017, 09:55 PM
The vehicle is a 2000 ML 320, giving codes PO170 and PO173
Automatic Climate Control Diagnostic Trouble Code (DTC) Memory Matt L W210 E-Class 126 06-14-2016 04:44 PM
Diagnostic trouble codes Chadted W202 C-Class 9 06-12-2012 01:38 PM
Push-button LED Diagnostic Trouble Codes ( DTC ) Ron MB R129 SL-Class 9 10-24-2009 08:21 AM
1996 W210 DTC codes via climate control system PPrash W210 E-Class 6 07-06-2007 04:53 PM
Diagnostic Trouble Codes adam25 W210 E-Class 3 04-20-2007 06:42 AM
