Mercedes-Benz Diagnostic Trouble Codes (DTC) for 1996+ models - Page 3 - Mercedes-Benz Forum
post #21 of 35 (permalink) Old 02-20-2014, 11:13 PM
Date registered: Oct 2011
Vehicle: 1995 E320 Special edition, 1994 E320 Coupe
Quoted: 133 Post(s)
amie2, this a great info, thank you.
It is about M 104.992 engine, I am looking for code related camshaft adjuster control malfunction. With other word: where from we could know, if the adjuster does not function? According OBD II code list there is not existing kind of malfunction. Neither check engine light, nor faulty code. Please help.
regards
peter
pbuchmueller66 is offline
post #22 of 35 (permalink) Old 02-21-2014, 01:14 AM
Date registered: Jul 2005
Quoted: 1042 Post(s)
The ODB II codes won't apply to the 1995 or the 1994 if either one of those is the car in question.
You will need the MB Star system or a high end shop tool like the Snap-On Solus with the Euro package to get the correct way into the diagnosis system of the car.
Noodles is offline
post #23 of 35 (permalink) Old 02-21-2014, 08:12 AM
Quoted: 133 Post(s)
thank you. It is not about 94 or 95 models. MB build 96-97 W210 model E320 with the same M104.992 engine, with the same camshaft adjustment system. W 210 already had OBD II, I just wondering, why there no malfunction code, how they know (where from?) if the camshaft adjuster not working, not in function.
Actually how you check this function? I made a parallell connector and hooked up an indicator lamp in the cabine. After normal ride, over 1200 RPM light should indicate the magnet get power ( actually there is common positiv, and the negativ switch on the ECM)
Summary, we have Star system and Snap On scan tools, but Mercedes doesnt release info about this malfunction. If yes, where is the code in the list?
post #24 of 35 (permalink) Old 03-10-2014, 07:37 AM
matspeed's Avatar
Date registered: Mar 2014
Vehicle: Mercedes S-Class Saloon 4 Door 2010
Thank you for this information, I was looking for P2033 definition a few years back.
matspeed is offline
post #25 of 35 (permalink) Old 03-10-2014, 07:52 AM
Quoted: 133 Post(s)
2033 ?
this thread about camshaft adjustment, how you come here with this code? strange
post #26 of 35 (permalink) Old 03-24-2014, 08:42 AM
Kajtek1's Avatar
Quoted: 1223 Post(s)
I think the list is up for update badly.
No P1482 what seems to be glow plug code
Kajtek1 is offline
post #27 of 35 (permalink) Old 03-24-2014, 02:47 PM
All I can add at this point is a post with PDFs of CDI and petrol codes from a sticky in the W211 forum.
http://www.benzworld.org/forums/w211...ror-codes.html
Noodles is offline
post #28 of 35 (permalink) Old 03-24-2014, 06:50 PM
Date registered: Jan 2014
Vehicle: 2002 SL500 Silver Arrow; 2005 CLK320 cabriolet; 2008 E350 4matic; sold 1985 380SE
Code Questions on my 2002 SL500.
I have some questions on the codes and sensors as a newbee:
My BAS and ABS lights are coming were on for two weeks and then the other day they both went out and were back on yesterday for about 30 minutes and now they are off.
The codes are C1140 and C1504. My mechanic put in a new steering gear box last week. Not sure if replacing the gear box has anything to do with the lights going off now?
Also, the check engine light has come on a couple of times and the code is Air Mass Flow Sensor? It too is off now. What does the AMF sensor do? Thanks,
BeardSL is offline
post #29 of 35 (permalink) Old 04-29-2014, 09:41 PM
Check Codes's Avatar
Vehicle: '01-E320 & 02-ST2
Quoted: 35 Post(s)
Beard, you're likely to get better advice in the R129 forum as that is specific to your car.
That said, both of the C codes relate to play in the steering column that causes the steering angle sensor to lose memory. That certainly sounds related to the work your mechanic did. Did you also check for codes before the work?
The MAF (mass airflow sensor, aka air mass sensor and a few others) measures the volume of air being drawn into the engine and sends that information to the ECU, which then adds fuel based upon that volume of air, engine load, temperature, throttle position and other relevant data. The MAF on your car also incorporates the IAT (intake air temp sensor) which is separate on some cars. This is also critical information for proper operation.
Bottom line, if your MAF is bad, you need to change it. You didn't mention which code(s) you got that led you to the MAF, but if you're upwards of 80K miles it's possibly done. Do yourself a favor and purchase a genuine bosch MAF assembly from a trusted vendor, avoid ebay inserts, etc. If they don't work properly (though they may turn off the light) they will not properly regulate fuel mixture, which among other things can ruin your cats, which are really costly.
Hope that helps.
Good luck and welcome aboard.
Check Codes is offline
post #30 of 35 (permalink) Old 11-25-2014, 01:31 PM
Date registered: Nov 2014
Hello ... i have a problem with M 203 , the throttle had been stopped more times until i will turn the engine off then on , and i used my scan that give me code P0203b (P0221) then i change the throttle but after two days the problem was replay !!! So please can some body help me. Thanks
abuadam is offline
  • Currently Active Users Viewing This Thread: 7 (0 members and 7 guests)
    Automatic Climate Control Diagnostic Trouble Code (DTC) Memory Matt L W210 E-Class 126 06-14-2016 04:44 PM
    Diagnostic trouble codes Chadted W202 C-Class 9 06-12-2012 01:38 PM
    Push-button LED Diagnostic Trouble Codes ( DTC ) Ron MB R129 SL-Class 9 10-24-2009 08:21 AM
    1996 W210 DTC codes via climate control system PPrash W210 E-Class 6 07-06-2007 04:53 PM
    Diagnostic Trouble Codes adam25 W210 E-Class 3 04-20-2007 06:42 AM
