suppressing a fuel tank on c240 2003 - Mercedes-Benz Forum
post #1 of 7 (permalink) Old 03-03-2009, 07:59 AM Thread Starter
Date registered: Feb 2007
Hello:
I am the owner of a C240 2003 4-matic. For the second time I am having problems with the fuel level sensors which are incorporated into the fuel pumps. That fact (that you cannot buy the fuel level sensor separately), plus the fact that this car has 2 fuel tanks, makes this fuel indicator problem a very pricy one and makes wonder why in the world Mercedes benz, in all its wisdom, did these 2 very stupid things:
1) Incorporate the fuel sensor INTO the fuel pump (so that you cannot replace it unless you replace the whole fuel pump) and
2) To make matters worse, put 2 (TWO) fuel tanks in the darn thing.
So, I ask: what happens if I suppress one of the tanks? will it work still?
Please advice.
Luis
taguato is offline
post #2 of 7 (permalink) Old 03-03-2009, 08:48 AM
Kajtek1's Avatar
Quoted: 1223 Post(s)
The sensor is part of fuel pickup in cars for last 100 years.
It is not that you can't replace the sensor alone. It is that MBUSA doesn't want you to buy small parts. When I had CV joint going back on my 4-Matic I had to buy whole $1200 axle. Check ebay for discount pump.
I never relay on fuel gauge while going low. Most of the cars will drive for 70 miles with the gauge showing 0, while old Volkswagen would make 130 miles. I reset daily meter at fill up and fill up by it
Kajtek1 is offline
post #3 of 7 (permalink) Old 03-03-2009, 10:01 AM Thread Starter
so what is the consequence of just using one fuel tank?
taguato is offline
post #4 of 7 (permalink) Old 03-03-2009, 04:30 PM
Kajtek1's Avatar
why?
Kajtek1 is offline
post #5 of 7 (permalink) Old 03-05-2009, 07:51 AM Thread Starter
like I said above. I don't want to have to replace BOTH pumps again. Can I just supress one of the tanks? or what happens if I replace just one pump?
taguato is offline
post #6 of 7 (permalink) Old 03-05-2009, 08:50 AM
Kajtek1's Avatar
How do you know you have 2 pumps?
I don't know your model, but haven't hear about twin tank with 2 pumps in it. Usually the electric pump is one tank and uses venturi effect of returning fuel to suck the fuel from the second tank to the first one. That system is also used in ML where pump seats in higher point of the tank and venturi "leg" sucks the fuel from the very bottom.
Kajtek1 is offline
post #7 of 7 (permalink) Old 03-05-2009, 05:00 PM
Date registered: Mar 2009
Vehicle: 1979 450SEL 6.9, 1991 300E, 1999 ML320, 1999 SLk230 KOMP, 2003 S430 4Matic (Certified MB Tech)
There is only 1 actual pump the other on is just a float
ernie300w is offline
    Fuel tank takes quarter tank full of gas less than what it used to take! Labik34 W140 S-Class 13 07-19-2008 04:15 PM
    Draining fuel tank, bleeding the fuel lines.. viper655rt10 W126 S,SE,SEC,SEL,SD,SDL Class 2 04-18-2008 01:12 AM
    Return fuel line disappears directly under the fuel tank - Where does it go? kburks1230 R/C107 SL/SLC Class 4 06-13-2007 09:06 PM
    Suppressing the model designator on the boot/trunk mcat R171 SLK-Class 35 12-09-2005 06:19 AM
    Was something loose? I filled my gas tank, and my fuel meter never reset to the full tank reading.. AC_ML W163 M-Class 5 08-20-2004 07:12 AM
