sprinter fanbelt? - Mercedes-Benz Forum
post #1 of 5 (permalink) Old 03-03-2009, 04:48 AM Thread Starter
Date registered: Mar 2009
sprinter fanbelt?
Has anyone got a diagram please as i am trying to change the fanbelt on my 208 sprinter and i can't find a diagram anywhere, the old belt snapped so i'm very stuck and need my van working today
1260pete is offline
post #2 of 5 (permalink) Old 03-03-2009, 06:09 AM
Diesel Benz's Avatar
Quoted: 37 Post(s)
I'm not sure if there are several options for the belt but I'd suggest you to post your VIN or at least the first six digits (numbers) of it.
Diesel Benz is offline
post #3 of 5 (permalink) Old 03-03-2009, 06:18 AM Thread Starter
Tis rainin heavy out there the reg is x138 ooj i had the same problem last time i did the belt but this time i just can't get it right at all
1260pete is offline
post #4 of 5 (permalink) Old 03-03-2009, 07:24 AM
Quoted: 37 Post(s)
You don't say where you come from, we don't have licence plates like that, I cannot pull the VIN from that info. Don't you have any papers about the car, VIN should be printed and easily available, also if it is raining.
There are so many different 208-models, I don't want to give a try with one example, it would be too likely to fail.
By the way, did you check your user manual, some have the serpentine belt diagram printed.
post #5 of 5 (permalink) Old 03-03-2009, 09:32 AM
Kajtek1's Avatar
Quoted: 1226 Post(s)
The diagram has to be printed somewhere. Some cars have a label in the engine compartment, some drawing in the manual.
The rule of thumb is that the crankshaft pulley needs to have about 180 degrees loop of belt on it. So looking on the engine from front and going clockwise the belt goes under the crankshaft pulley, wraps it toward 2 o'clock, where usually is a tensioner on idler pulley, than goes back toward 8 o'clock, loops on whatever is there and than wraps around all the pulleys on the engine.
Years ago in Tennessee I had 3 senior mechanics and supervisors of Peep Boys working over 1 hr on my W124 and they managed to put the belt wrong, giving me a BS that the slippage was due to bad tensioner. Next day at campground took me 5 minutes with manual to figure it out.
Kajtek1 is online now
    07 and up Sprinter kmessinger Benzworld Site issues forum 7 09-04-2011 10:46 AM
    sprinter taztaz W901-905 Sprinter 0 03-12-2008 01:03 PM
    Please help! Replacing fanbelt on 230E. . . jesseza W124 E,CE,D,TD Class 4 11-28-2005 10:39 AM
    Ultimate Windsurfing Van - Freightliner Sprinter Van Dodge Sprinter Saigon76nyc W901-905 Sprinter 3 10-06-2005 11:17 AM
    Mercedes 1990 500SL Fanbelt troubles! Pleas Help! Bublee General Mercedes-Benz 0 06-16-2005 01:54 PM
