!995 Wagon E320 questions! - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 03-01-2009, 08:12 AM Thread Starter
rbalc10279's Avatar
Date registered: Feb 2009
Does anybody know what a power pack is? I've been told mine has 3 is that the same as spark plug wires? Also how do you change a outside temperature sensor. It shows nothing inside cleaned it up outside how do you know it's working?
rbalc10279 is offline
post #2 of 3 (permalink) Old 03-01-2009, 09:17 AM
ohlord's Avatar
Vehicle: 1994 E320 Wagon,1999 E320 Wagon,2000 E 320 Wagon, MGB Track/Rally, ,1988 300E ,more....
you have 3 each one controls and amplifies the voltage to the spark plugs for
2 cylinders,on your M104 L6 engine.
You do not need to replace them if they test good.If you have a misfire condition you can swap any 2 coils and see if the misfire follows that coil.
What are your symptoms or are you just interested in learning about your engine?
Always remember on the 95 M104 inspect the wire harness if you are having ignition issues.You may have a defective one installed and the wires break down.Replacement article on ***************** in the resource diy section and spark plug change article for your engine is down in
our w210 section but it is the same M104 as in your 95
picture of Coil
temp sensor make sure it has not come unplugged or you can replace it
carries it.
00-02 drivers side self dimming heated mirror
17mm special spark boot tool
O2 plug and play sensors
16mm spring loaded swivel spark socket
trans dipstick and magnet
Mercedes Benz Lyrics
Artist(Band):Janis Joplin
"Oh Lord, won't you buy me
a Mercedes Benz"
"Follow Peace,center Life"
ohlord is offline
post #3 of 3 (permalink) Old 03-01-2009, 07:42 PM Thread Starter
rbalc10279's Avatar
Is the temperature sensor located behind the license plate? It didn't look like that. It was more flat and a round head or am I suppose to take that off and put the one that's shown on the image to replace that one? You been a big help. Thanks again I don't know if you got my reply from the email I sent you about my front speakers having distortion. Let me know.
    Recent Purchase Of 2004 E320 Wagon Questions balthus W211 E-Class 14 02-26-2009 11:21 AM
    Questions about E320 Wagon MAVA W124 E,CE,D,TD Class 7 04-24-2008 02:31 PM
    2000 E320 Wagon Test Drive + Questions Hecdog W210 E-Class 6 11-09-2006 09:43 AM
    e320 cdi Estate (Wagon) - Questions - USA? roane10 W211 E-Class 1 03-18-2006 11:58 AM
    Picked up "new to Me" 94 E320 Wagon, a few questions.. hsv5000 W124 E,CE,D,TD Class 33 03-10-2004 06:05 PM
