oil change - Mercedes-Benz Forum
post #1 of 10 (permalink) Old 02-28-2009, 07:43 AM Thread Starter
Date registered: Feb 2009
Vehicle: 1995 E320 and a 1987 420 sel
Send a message via MSN to sammyz5 Send a message via Yahoo to sammyz5
oil change
decided to change my own oil on my95 e320 and i cant find the oil filter canister plz help
sammyz5 is offline
post #2 of 10 (permalink) Old 02-28-2009, 10:54 AM
Date registered: May 2005
Vehicle: '07 GL320CDI
Quoted: 2 Post(s)
Best help for you is advice to take your car to a professional.
Next best is for you to buy the Mercedes W124 service DVD at your dealer.
Kent Christensen
Albuquerque
'07 GL320CDI
lkchris is offline
post #3 of 10 (permalink) Old 02-28-2009, 12:54 PM
Date registered: Aug 2008
Vehicle: 2008 E320 Bluetec, 1988 560SL totalled unto death). 1997 Dodge Ram 1500, 1983 300CD
Quoted: 178 Post(s)
oil filter location
Will someone please just tell this guy where his oil filter is? Not having serviced one of these I cannot help him. If I knew I would.
rocky raccoon is offline
post #4 of 10 (permalink) Old 02-28-2009, 01:17 PM
Check Codes's Avatar
Vehicle: '01-E320 & 02-ST2
Quoted: 35 Post(s)
Hey, Sammy.
It's an element type, you have to unscrew the housing located in the back of the engine (removed from top). You'll need a fluted wrench for it that can be bought at most auto parts stores, but measure yours and count the flutes to be sure you get the right one.
Unscrew the housing, pull it out, swap the filter, install new O-rings, reassemble.
FWIW, you posted into the general forum, there is a forum that is specific to your car and you'll get the best advice and tips if you post in there when the issue relates to your car and not MB generally. It's the W124 forum, scroll down the main page into the sedans section, then you'll see it.
Take care and enjoy the ride,
Greg
Check Codes is offline
post #5 of 10 (permalink) Old 02-28-2009, 01:18 PM
utiadam's Avatar
Date registered: Mar 2008
Send a message via AIM to utiadam Send a message via MSN to utiadam Send a message via Yahoo to utiadam
should just be the large black plastic cap in front of the engine.
utiadam is offline
post #6 of 10 (permalink) Old 02-28-2009, 03:09 PM
Date registered: Nov 2008
Vehicle: 92 SL500, 95 E320, 99 ML320, 98 Harley Davidson's Low Rider & Wide Gluide
its located top rear, drivers side.
alemlsl is offline
post #7 of 10 (permalink) Old 03-01-2009, 12:16 AM
Quoted: 35 Post(s)
Please don't take this personally -- since there are lots who do this (including me in the past) -- but unless you have specific knowledge on an issue it's best not to take a shot at answering posts. While the more modern MB engines do locate the filter at the front, his L6 is hiding at the back of the engine.
Greg
post #8 of 10 (permalink) Old 03-01-2009, 09:03 AM
Kajtek1's Avatar
Quoted: 1289 Post(s)
Also the older models don't have the flute ends, but a big hex that can be catch with big crescent wrench, or adequate 6-point socket.
Kajtek1 is online now
post #9 of 10 (permalink) Old 03-01-2009, 09:46 AM
Diesel Benz's Avatar
Quoted: 39 Post(s)
This is something I was not sure about this car. From EPC it appears like late W124 models would have had the more modern plastic oil filter cap while older models certainly have the metal plate (I first thought all W124 cars would have the older type). Either way, should be easy to remove the oil filter once the owner finds it.
Diesel Benz is offline
post #10 of 10 (permalink) Old 03-01-2009, 04:30 PM
Date registered: Mar 2009
Vehicle: 1979 450SEL 6.9, 1991 300E, 1999 ML320, 1999 SLk230 KOMP, 2003 S430 4Matic (Certified MB Tech)
You have a 104 motor in it and the filter is located in the rear of the engine
ernie300w is offline
Oil Change - Regular Oil vs. Sythentic (A lesson learned...) and a question? swiftwind W163 M-Class 61 03-11-2009 12:13 PM
Just did my Oil change & air filter change. What else does Service B entail? RaleighMB W210 E-Class 5 03-07-2009 06:39 PM
Poll: mileage between oil change / brand of oil / DIY or dealer ?? Thanks! Rohf (Seattle) R170 SLK-Class 27 08-05-2008 07:58 PM
Oil Change in 81 240d cause lack of power and lower oil PSI? Cobb2 W123 E,CE,D,CD,TD,TE Class 12 07-15-2008 10:51 PM
oil exceeds max warning....i get this everytime i get an oil change with 8.5 qrts..is that too much. concerned C208/A208 CLK-Class 2 10-21-2001 05:56 PM
