post #1 of 2 (permalink) Old 02-27-2009, 07:08 AM Thread Starter
Date registered: Feb 2009
Hi anyone know where I can get a replacement motor for the central locking pump on a W220 S320?
Sunday mechanic is offline
post #2 of 2 (permalink) Old 02-28-2009, 09:11 PM
n5160u's Avatar
Date registered: Apr 2004
Vehicle: 2000 Designo SLK-05 C230WK-05 E320CDi-2010 GLK 350
Those motors are nearly identical to the motors sold in hobby shops for R/C cars. There is one very big difference though. The output shaft on the central locking pump is as much as 50mm longer. When I needed to replace a burned and melted motor in an older SLK320 (Pump motor typical failure caused by housing filling with water and shorting motor) and found there was nobody with any parts in stock, I used a Tamiya R/C motor as an act of desperation since the cars buyer was picking the car up the next day. I ended up taking the new motor apart and replaced the short shaft with the longer one from the old burned set. Never expected it to work but four years later when the new owner was trading up he asked me why I was always asking how the remote locks were working.
Bottom line: Nobody supplies replacement motors. They all expect you to replace the complete assembly. If you try what I did there is no guarantee it will work or fit.
Potato Chip, custom canuter valve, low-friction muffler bearings, synthetic turn signal fluid, Hi-Definition Progressive Scan Wiper Blades.
Law-makers are supposed to regulate in the interest of the public as opposed to regulating in the interest of the regulated party.
If it says Pratt and Whitney on the outside it better say Martin Baker on the inside.
n5160u is offline
    Central Locking and boot locking and closing elabhakrin1 R230 SL-Class 14 02-20-2013 03:04 AM
    Central locking pump + motor Nime W168 A-Class 3 01-07-2009 03:09 AM
    Central Locking Makes A Machine Gun Like sound When Locking UKML55 General Mercedes-Benz 3 10-20-2008 02:59 PM
    Central Locking pump faulty - worth replacing or new locking motors? jpdp.au W210 E-Class 2 11-26-2007 03:03 PM
    Central Locking Pump Motor dpaterso W140 S-Class 9 11-04-2006 12:04 PM
